poolboy
NickMorgan said:Dale,
Make sure that you adjust the rear shoes before you adjust the hand brake. If you do it the other way around you will never get any braking efficiency from the rear brakes using the pedal.
Nick
Nick, with all due respect, I don't see it that way. If you get the brake shoes on both wheels in full contact with the drums by the handbrake cable adjustment, then release the handbrake, the shoes can return to the same distance from the drums because of the limiting factor of the cable.
Then just use the adjuster to take up the distance between the now equal starting positions of the shoes and full contact with the brake drums.
I'm not saying you have to adjust the handbrake cables every time you need to adjust the brakes, just if you are having problems with handbrakes or installing new shoes.
At any rate, I don't see how doing the hand brake first would negatively affect the efficiency.
I'm opened minded about it and would like to hear how it would affect the braking efficiency, though.
