[ QUOTE ]
OK Dale, here we go...
Edit: Make sure that the spare rotor is aligned properly with the notch in the shaft, and it's pushed down fully. Also, use the spare cap if there is any damage from the rotor breaking.
The first thing we want to do is get back up to TDC like you did on a previous occassion. However, this time, we'll make one change so we can get your timing pretty close to where it should be. I don't know what kind of timing marks you have on your damper pulley, so I'll cover all the possibilities.
Remove the valve cover. Now turn the engine clockwise (as looking from the front) and look for the intake valve on #1 piston (second from the front) to open. Keep turning until it starts to close and then start watching for the TDC mark. This time, I don't want you to go all the way to the TDC mark.
If you have degrees marked on your damper, bring it up to the 10 deg mark BTDC (Before Top Dead Center). That would be to the right of the TDC mark as you're looking from the front.
If you don't have degrees marked, but have two marks, align the FIRST mark (the one to the right) with the pointer.
If you only have one mark, stop the rotation about 3/8"-1/2" before the TDC mark.
This will put you at about 10 deg BTDC. You'll see in a bit why were doing this. Make sure both valves on #1 cyl wiggle just a little to indicate they are closed.
Now, pull all of the wires from the distributor cap, including the coil wire. Take off the cap. Loosen the distributor and rotate it into position so it looks like the pictures of the other distributors in this thread. They looked like the advance mechanisms were pretty much parallel with the engine block.
Attach a test light or voltmeter to the coil. Do this on the (-) side, the wire there should go to the distributor. If using a voltmeter set it at DC volts, and clip the red (+) lead from the voltmeter there. Hook the other end to the negative on the battery. This goes for the test light or the voltmeter.
Turn the ignition on, but DO NOT CRANK THE CAR OVER, or you'll have to start over again.
If the test light is on, or the voltmeter registers, turn the whole distributor CCW, until the light goes off. Then turn it back until it just lights. Tighten the distributor.
If the test light is off when you turn on the ignition, turn the distributor CW just until the light goes on or the meter registers. Tighten the distributor.
You have just set the timing statically. You can put the valve cover back on now.
Look to see where the rotor is pointing, and see which tower on the cap it lines up with. That is cyl. #1. Put the wire in and hook it up to #1 plug. Continue around the cap in a CCW manner with the rest of the wires. 1-5-3-6-2-4... put the coil wire back on.
Start the car.
[/ QUOTE ]
Art,
You need to copyright this as written.....
