Cross Rod Correct Length
Healey Nut
Hi All,
So work on the '62 continues. However, I am finding that the front wheel alignment is way off using the front upper cross rod that I have.
It's 19 1/2” long without ball joints. With the front wheels ball-parked at correct alignment the rod appears to be at least an 1” too long.
There's loads of thread in each end so I could just lop off a bit on each end or take it all off the regular thread end and tap deeper to get my thread length back … simple fix, but I want to make sure that that is indeed the case that the rod is possibly from another vehicle.
Anyone care to measure the center cross rod length for me? Just the rod, end to end.
Thanks.
BobHaskell
The length you have is correct. If you do cut a bit off each end, remember that one end has a left hand thread.
What is your camber setting? Factory spec is 1deg positive; if you've somehow changed it towards negative it will 'spread' the front wheels outward, potentially to the point of too much toe-out (it should be slightly toed-in). Racers, who often run a lot of negative camber, have a couple solutions, including shortening their cross-rod. The most elegant, IMO, is adjustable side tie-rods--our cars should have had them from the factory--but they aren't readily available (supposedly, select ones from certain Nissans work, but I haven't been able to track them down).
My BN2 has Kilmartin adjustable shock plates, because when we got it it had excessive negative camber (no apparent damage to the chassis). When we adjusted alignment, my father insisted we do it with the center spoke of the steering wheel at vertical; I said it didn't matter since the wheel can be positioned anywhere you wanted it to be (which is true). I bought an at-home alignment kit and started pulling camber closer to zero and, sure enough the center spoke went from 12 o'clock--I'd set it there when I installed a Lempert Wheel--to about 2 o'clock, which I cannot explain because when toe is adjusted it pulls both wheels in or out the same amount. I should never have argued with Dad (at least about mechanical stuff).
Healey Nut
Healey Nut
I have to admit I didn’t check the camber as it’s only adjustable if you have the adjustable plates and bushings .
I chopped about 1/2”off the RH thread and , tapped it deeper , drove the tie rods right in as far as they would go and assembled it on the car . Then I took 2 8ft pieces of uninstrut and tie wrapped them to the spokes to create 2 long straight edges and set the toe in at neutral for now .
The engine is now in the car so I can now tighten and set all the front suspension bushings , trunnions etc etc that you need the weight of the engine for then I will check the camber/toe in etc all over again .
This once I switch the anti roll bar plates side for side as some dummy put them on the wrong sides ……DUHHHHH.
BoyRacer
You have the steering arms reversed. They are handed. If you reverse them the cross rod will become the correct length and you can get the correct toe in.
Richard, please explain "You have the steering arms reversed. They are handed." Are you referring to the side tie-rods? Moss shows one part#, 2 required for all cars (my BMC parts book is still packed away; we've been unpacking unimportant things, like food, clothing, etc.).
Healey Nut
Healey Nut
According to the Moss parts the steering arms are handed . However if you switch them side for side then the taper for the side rods will be upside down so you would have to switch the arms on the steering box and the idler side for side and we know they will only fit in one position on the shaft due to the special spline they have . I also know I did not remove the arm on the idler so I know they were not switched around by mistake .
basically this is how they make a RHD car an LHD car .
But it has no bearing on the centre cross rod length .
CraigC
Healey Nut, post a picture of how you have the cross rod and side rods installed. This will either point out the problem or end the discussion of incorrect parts placement.
BoyRacer
Let me try this again. The steering arms are approximately 9" long and attach to the spindles. They are not straight. They are not identical. They have a slight angle to them. They are "handed". There is a left hand side arm and a right hand side arm. If you install them on the correct sides ..... the arms will angle up. If you install them on the wrong sides ..... the angles will point down. If you have them on the correct sides the tie rod/cross rod will attach to the steering arms and the wheels will be pointing straight ahead. If you have them on the worng side the angles will point down and when you connect the tie rod/cross rod to the steering arms the wheels will be toed out.... a lot.
Also, the tie rod (cross rod) ends (where the nuts attach) should be pointing up when correct. Because you have the steering rods reversed you are now using the wrong holes in the idler arm and pitman arm for your connections.
Just swap steering arms and you will be fine.
Adjusting the length of the tie rod (cross rod) will only change toe-in, nothing else. It has no affect on camber.
Thanks for the explanation; I didn't think of them because they aren't often messed-with (Moss calls them 'levers').
re: "Adjusting the length of the tie rod (cross rod) will only change toe-in, nothing else. It has no affect on camber."
But the opposite is true, no?
Healey Nut
Healey Nut
Ok I see my mistake . I have to switch the steering arms (back of spindle) so they angle up.
change the short cross end position to the back hole in the idler arm and steering box arm .
Finally the centre cross rod should be nuts on top mounted in the front most forward holes in the idler and steering box arms .
more work to do .
Serves me right for buying a car in boxes with nothing marked .
Keoke
Healey Nut
Healey Nut
All sorted boy racer was 100% correct . Steering arms were reversed etc . All ok now .
F TR2/3/3A Throttle linkage cross rod Triumph 4
oxford steering cross rod Austin Healey 13
bighealeysource Question on toe in and cross rod assembly Austin Healey 4
mjobrien Dimensions for Tie Rod and Cross Bar for 100 Austin Healey 6
S MGB Transmission cross member re-install MG 14
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
S TR2/3/3A Clutch cross shaft bushings? Triumph 5
G 100/6 Radiator cross member Austin Healey 6
G TR2/3/3A Cross reference for hardware Triumph 8
R Wanted WTB Spitfire race/auto cross car Triumph Classifieds 1
J TR6 TR6 Cross Tube Differences? Triumph 6
J front cross member height from bottom to floor on BJ8 Austin Healey 5
gbtr6 TR6 TR6 cross flow head, or aluminum head Triumph 3
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
S Difficulty removing end rods and cross rods Austin Healey 11
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
S TR2/3/3A cross tube back on Triumph 3
J E Brake cross rods Other British Cars 6
PatGalvin TR2/3/3A Engine Cross Tube Challenges Triumph 6
RJS TR4/4A Clutch Slave mount into cross shaft Triumph 3
stuntflyr Solo cross country Healey frame transport. Austin Healey 17
Boggsy64 MGB Front Cross member pads MG 4
G 100-S in 1000 K cross country race Austin Healey 6
H gear reduction starter cross reference Austin Healey 12
C 1500 gt pre cross flow Other British Cars 4
andrea Austin Healey 100/6 cross flow heater pipeclips Austin Healey 3
M TR4/4A TR4A muffler hanger to cross member attachment Triumph 13
C Ford 1500 Kent Pre-Cross Flow Mystery Lotus 20
F Bias ply tires [cross ply tyres]- more for less? Austin Healey 36
J TR6 TR-6 Clutch Fork Cross-Bolting ? Triumph 2
G Auto cross tire pressure Spridgets 7
T MGB MGB cross country trip - NY Times MG 0
K TR2/3/3A TR3 Boot: The criss cross support bracket Triumph 2
Got_All_4 Auto cross videos from TRF Summer Party 2010 Triumph 0
T TR4/4A TR4/A cross-tube question Triumph 9
Nigel_Johnsfolly LBC Cross-Country Rally Other British Cars 2
Nigel_Johnsfolly LBC Cross-Country Rally Spridgets 0
I Bugeye spares supplies for a cross country trip? Spridgets 13
mjobrien Top cross section at the front header / bow Austin Healey 0
Lynn Kirkpatrick MGB-GT MGB-GT Tranny Cross Member MG 5
M Wire wheels- cross fitting Spridgets 12
hondo402000 TR6 TR6 Clutch cross shaft Triumph 9
aeronca65t Spark Plug Cross Reference Restoration & Tools 3
GeeBee1 Cross Flow Head on E Bay Spridgets 1
PAUL161 Spark Plug Cross Reference. Restoration & Tools 1
T Helpful cross reference site for parts Triumph 6
T TR4/4A Fram or other spin-on cross reference for TR4a Triumph 7
newmexTR3 TR2/3/3A TR3 front cross tube needed Triumph 3
T Cross your fingers..... MG 8
newmexTR3 TR2/3/3A TR3 cross-tube dimensions Triumph 2
