Crankshaft Starter Nut
AUSMHLY
What is the purpose of the "ears" on the end of the crankshaft nut? Is ears the correct term?
Why do the ears on my 64 BJ8 look different from the photo Moss has?
Can I put a long steel rod though the slot on my nut to turn the engine over to find TDC, or will it brake those off.
John Turney
Those "ears" are for a manual starting handle. This basic engine was used on other BMC models, which may have had a provision for hand cranking. So, yes, you can use those for turning the engine over.
AUSMHLY
AUSMHLY
Thanks John.
Is there a starting handle tool?
The nut Moss sells looks like those safety nuts that a screw driver can screw on but can't screw off. Different from the one my car. Why is that?
John Turney
No starting handle for a Healey. It would have to come through the radiator. If you look at the front of a Triumph TR2, TR3, or TR4, you would see an opening for a starting handle.
Mine is like the Moss one. The idea is that when the engine starts, it kicks the handle out so it doesn't spin you around, flapping you on the ground until you let go.
Why is yours different? Maybe they figured out that hand cranking wasn't happening anymore and you could now rotate the engine in both directions by hand (when out of the car).
kozelding
Yeah, the original nut has long, hook-like tines that would actually be useful for catching the end of a hand-crank rod (if only the engine was installed in a car that provided access to it).
The replacement nuts, like the one pictured above, have abbreviated tines that I think are just for show. The benefit of the short/fake tines is you can remove/install the nut without lifting the engine (that is, it clears the front frame brace). With the original nut, the tines get in the way.
AUSMHLY
AUSMHLY
True that. Photo shows two dent in the frame brace from the two tines.
twas_brillig
We've got the same style nut on some 4 cylinder Spridget engines; we had a 69 Citroen ID 19 back in the 70s with a similar nut and the magic extendable lever thingy for changing tires also functioned as a crank start. And, yeah, I used it a couple of times to start the engine back in the day with electrical problems and a low budget. Doug
dougie
I've hated that ugly nut forever, I finally kicked it to the curb....
Marty V
Does anyone know the correct “crankshaft nut” size for a 1958 TR 3? The car has been sitting for 20+ years and I would like to see if the engine is seized-up. Planning to remove the spark plugs and add a little oil(?) to the cylinders before trying to turn over engine with a socket (size?) and extension/breaker bar. Thanks for any advice.
Editor_Reid
Platinum
Hi Marty, You're more than welcome to post your question here, but there's also a Triumph Forum where you are more likely to find folks familiar with your subject. Cheers.
T Wedge Anyone need a TR7 crankshaft or starter? Triumph 0
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 3
B TR6 Crankshaft long seal surface Triumph 5
MKIII_Joey Crankshaft Bearing Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
B General MG Crankshaft Nut Removal MG 4
W Crankshaft Oil Seal Austin Healey 3
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
B MGB Mgb crankshaft end play shims MG 2
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
T crankshaft (rear) bearing leak Spridgets 2
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
R Wanted 3 main crankshaft MG Classifieds 0
glemon TR2/3/3A Crankshaft Question Triumph 3
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
M TR2/3/3A Crankshaft Pulley Configurations Triumph 3
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
S TR4/4A Fair price for a crankshaft? Triumph 2
charleyf TR2/3/3A crankshaft hardening Triumph 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
O Wanted TR 3 Crankshaft please... Triumph Classifieds 1
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
C Tough Bolt on front of Crankshaft Spridgets 16
TRMark TR4/4A Prepping Crankshaft Triumph 4
D TR2/3/3A crankshaft shims to align timing sprovkets Triumph 4
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
tinman58 TR5/TR250 Front crankshaft seal Triumph 0
2billydavies TR2/3/3A removing con rod from crankshaft Triumph 4
J TR2/3/3A Crankshaft thrust washers. Triumph 2
C Crankshaft pulley / damper Austin Healey 5
HJR TR2/3/3A Crankshaft crank bolt head[108498] Triumph 10
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
M_Pied_Lourd TR2/3/3A TR3A Crankshaft Question Triumph 3
B crankshaft/cam timing Austin Healey 10
RedTR3 TR2/3/3A TR3 Crankshaft Options Triumph 10
Gerard 1098 10CC crankshaft Spridgets 14
vette Timing Cover crankshaft pulley seal Austin Healey 6
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
M Healey Crankshaft Thrust Washer Thickness Austin Healey 3
