It's good that you checked the alignment. Many builders would have missed it! But, +1 for doing what it takes to get perfect alignment. Be sure the cam is seated fully against the block and not stopped against a lifter or the rear cam galley plug.
If position and end play are right, use whatever thickness it takes. The Moss catalog mentions a procedure found in the service manual, which might add confidence.
Bob
