I removed the air filters for a better view of the choke mechanism. 1. It seems that when the choke pull is pulled out the front jet is lowered but the rear jet dosn't move. Is there a spec length that the choke control rod should be?
2. How far should the jets drop down.....1/4"
3.What is the spec for the distance between the "cam and the screw for the higher idle" when the choke is "not" actuated?
