I was driving the car on Friday night and all was well until I had been driving about 30 miles, and then the temperature began to creep back up again. After the car cooled off, I found the overflow tank full, but the radiator down 4 to 5 inches. There's definitely some nasty stuff mixing in with the coolant, but I can't tell if that is something that is recent, or the product of 46 years of detritus. My gut is I have a small head gasket leak that only rears its head when the engine has been running for some time. I'll try retorquing the head again and see if that helps things out. Otherwise, I'll likely have to change the head gasket again. Like so many other things I've done on the Sprite, I usually end up doing a better job the second time around than my first attempt, so I'm not overly pressed if I have to go this route.
