Control Head Screws
Gordon_Dedrick
Anyone out there know what size and pitch the three screws are to attach the two halves of the control head together on a 59 TR3A?
Nothing in my assortment seems to fit and I do NOT want to strip the brass inserts.
Gordon
martx-5
More then likely, they are British Association (BA) threads if they are smaller then 1/4". A lot of the screws smaller then 1/4" on the TR3 are BA threads. See the chart I linked to. The only sizes that I've run across so far are 2BA and 4BA. If the screw measures about 0.142" it's a 4BA, 0.185" = 2BA.
mapleaf
I had one measured at fastenal a couple of years ago and they gave me these numbers: M 2.5 x 60 x 6 Unfortunately, they only sold them in 100's. I made do with the old ones.
Twosheds
Gordon
If you're looking to buy them, Moss has 'em for $1.35 each, part number 323-315.
martx-5
Gordon
Those are the grub screws holding the control head in the steering column...I get the feeling that Gordon is looking for some other screws...or am I totally off-base??? :confuse:
Twosheds
I'm the one off-base here. Oops.
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 4
71TR6 TR2/3/3A Control Head horn contact Triumph 7
Lin Another Trafficator/Control Head Question Austin Healey 10
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
P TR2/3/3A TR3A Steering Control Head Harness Triumph 7
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
C TR2/3/3A Control Head Rebuild Help Triumph 1
Got_All_4 TR2/3/3A Control head wiring help Triumph 11
C TR2/3/3A Control Head wiring Triumph 18
trotti Control head / trafficator questions Austin Healey 14
B Stator/Traficator [Control Head] Question Austin Healey 2
J TR2/3/3A Correct trafficator control head? Triumph 4
K TR2/3/3A The Control Head on the Steering Wheel Triumph 3
Kleykamp TR2/3/3A 1961 TR3 control head. Triumph 5
G TR2/3/3A Control Head How to Repair Triumph 5
G TR2/3/3A Control head Lubricant? Triumph 3
Y Fault in Steering Wheel Control Head in BT7mk1 Austin Healey 3
G TR2/3/3A Control Head Video Triumph 3
R trafficator/control head rebuild Austin Healey 10
luke44 TR2/3/3A Control Head Ground? Triumph 1
Scotsman TR2/3/3A Signal switch on TR3 Horn Control Head not canceling Triumph 20
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
O TR2/3/3A TR3 Control Head Install Triumph 10
B Another wiring question 57 smallmouth control head Triumph 2
O TR2/3/3A TR3 Control Head Stator Tube Install Triumph 5
Superwrench Steering Control Head Assembly Austin Healey 4
Tinkerman 60 TR 3 A Control Head & Steering Wheel Triumph 9
S control head canceller 180 out Triumph 3
J TR2/3/3A TR3A control head question Triumph 4
tmc TR2/3/3A TR3A control head disassembly Triumph 4
DavidChandler TR2/3/3A Tr3A Control Head Triumph 16
K TR2/3/3A Internal view of a tr3 control head Triumph 7
mountainman TR2/3/3A TR3 Control Head Wiring Triumph 11
ekamm TR2/3/3A TR3a horn/turn indicator control head Triumph 13
AweMan Control head question Triumph 4
donbmw link to control head rebuild Triumph 5
F TR2/3/3A TR3 Turn Signal/Horn control head Triumph 4
P Steering Control Head Triumph 2
G Adapting adj. wheel control head to non adj. wheel Austin Healey 5
J TR2/3/3A TR3 control head internal pictures? Triumph 11
