Control head question
AweMan
I need to purchase a new control head for my Tr-3
my question is.
Moss $209.00 and $43.95 for the wire harness = $252.95 + shipping
T.R.F. On sale $177.50 looks like it comes with the harness ... does it? If not $39.95 on sale = $217.45 + shipping.
The real question is .... Is there a difference in quality?
Is the Moss control head worth the extra money?
B.T.W. according to their catalog V.B. was out of the ball park price wise.
Anyone know for sure which is the better product?
MGTF1250Dave
Aloha Kerry,
I would suggest you contact TRF either by phone or e-mail their customer service and ask them. I recently inquired about a rear dog leg body panel by e-mail and received a response the next day. It probably would have been quicker, but we had a six hour time difference.
I would suspect but can not be certain that there is probably one maker of the control head so they are more or less equal.
Is the one for your car missing? I ask because they can be repaired. Here is a link to a excellent article written by Clive Elsdon. It describes disassembly in great detail with plenty of photos included. Reassembly is not described but just work back wards. It is the fourth article down in the archives, "Disassembling the Control Head in the steering column"
https://www.tr-register.com.au/files/technical.htm
Good luck.
AweMan
AweMan
Thanks to my sister {long story} the original was sold for ?
{some here know what the ? means}
In any case at best I have a few bit and pieces from the last time I repaired the original but not enough to make a complete unit.
TR3driver
Great Pumpkin - R.I.P
Current sale price from TRF is even lower than that shown in the web catalog. Until next 11/14, the non-adjustable is $130, adjustable $135.
I've seen them, and seen people using them, the TRF version seems to work great. If the Moss version is better, I don't see how. (And as noted, they are almost certainly from the same source. The control heads were NLA for many years, then suddenly both vendors had them at the same time.)
Be sure to get the one that matches your steering wheel, tho.
If your spare parts include the outer Bakelite ring, let me know if you'd like to sell it. I've got several of them that are complete except for that ring.
angelfj1
You should be aware that Moss is probably the largest LBC parts supplier worldwide. Although Charles (TRF) has many bits and pieces manufactured special for his company, Moss actually supplies many of the most commonly used parts. I would not be surprised if TRF buys the control head from Moss.
fja
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
Lin Another Trafficator/Control Head Question Austin Healey 10
B Stator/Traficator [Control Head] Question Austin Healey 2
B Another wiring question 57 smallmouth control head Triumph 2
J TR2/3/3A TR3A control head question Triumph 4
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 4
71TR6 TR2/3/3A Control Head horn contact Triumph 7
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
P TR2/3/3A TR3A Steering Control Head Harness Triumph 7
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
C TR2/3/3A Control Head Rebuild Help Triumph 1
Got_All_4 TR2/3/3A Control head wiring help Triumph 11
C TR2/3/3A Control Head wiring Triumph 18
trotti Control head / trafficator questions Austin Healey 14
J TR2/3/3A Correct trafficator control head? Triumph 4
K TR2/3/3A The Control Head on the Steering Wheel Triumph 3
Kleykamp TR2/3/3A 1961 TR3 control head. Triumph 5
G TR2/3/3A Control Head How to Repair Triumph 5
G TR2/3/3A Control head Lubricant? Triumph 3
Y Fault in Steering Wheel Control Head in BT7mk1 Austin Healey 3
G TR2/3/3A Control Head Video Triumph 3
R trafficator/control head rebuild Austin Healey 10
luke44 TR2/3/3A Control Head Ground? Triumph 1
Scotsman TR2/3/3A Signal switch on TR3 Horn Control Head not canceling Triumph 20
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
O TR2/3/3A TR3 Control Head Install Triumph 10
O TR2/3/3A TR3 Control Head Stator Tube Install Triumph 5
Superwrench Steering Control Head Assembly Austin Healey 4
Tinkerman 60 TR 3 A Control Head & Steering Wheel Triumph 9
S control head canceller 180 out Triumph 3
tmc TR2/3/3A TR3A control head disassembly Triumph 4
DavidChandler TR2/3/3A Tr3A Control Head Triumph 16
K TR2/3/3A Internal view of a tr3 control head Triumph 7
Gordon_Dedrick Control Head Screws Triumph 5
mountainman TR2/3/3A TR3 Control Head Wiring Triumph 11
ekamm TR2/3/3A TR3a horn/turn indicator control head Triumph 13
donbmw link to control head rebuild Triumph 5
F TR2/3/3A TR3 Turn Signal/Horn control head Triumph 4
P Steering Control Head Triumph 2
G Adapting adj. wheel control head to non adj. wheel Austin Healey 5
J TR2/3/3A TR3 control head internal pictures? Triumph 11
