M
Member 10617
I am looking into replacing some odd wiring on my TR3 from the regulator to the generator.
There are two wires, as most of you know: a yellow wire from "D" to the main generator terminal (yellow pvc, 28 strand), and a yellow/green wire from "F" to the field terminal on the generator (yellow/green, 14 strand).
Here is the problem and the mystery. The yellow and yellow/green wires lead from the control box and disappear in the tape-enclosed harness. When the wires emerge from the harness on the way to the generator, they are both black wires (I believe someone spliced in new wires when the old generator was replaced with a new one and did not use the properly coded wires).
Being very close to the exhaust these wires have suffered greatly from the high heat and could stand replacement.
Mystery: I checked the continuity between the "D" terminal on the control box and the main generator spade terminal to make certain I was looking at the proper wire and got a continuity signal. But, I also got a continuity signal when I left the probe on "D" and touched the field terminal on the generator with the probe (!!).
How can that be if there are two separate wires running from "D" and "F"?
I am thinking of disconnecting the wire that links "D" and the main generator terminal and running a new, properly coded, wire directly from "D" to the main generator terminal, and the same thing from "F" to the field terminal, entirely bypassing the old wires and harness, leaving the old wires in place but disconnected for the time being.
Any idea why I would get continuity from "D" to the generator termonal AND the field terminal? Any thoughts on running wires directly from the control box to the generator (outside of the harness)?
I hope I've described all this accurately...
