Hi all,
Just curious what the collective wisdom is for using contact adhesive on open cell foam. I am rebuilding the seats on my TR4A, and am using Weldwood high temp Landau adhesive https://www.dap.com/dap-products-ph/weldwood-landau-top-trim-high-heat-resistant-contact-cement/ at the suggestion of several folks here as well as on a hot-rodding forum. I am brushing, not spraying it on.
I have made a few trial bonds with the stuff and am struggling to get a strong bond... I am not getting an "instant" bond, and am able to pull apart the pieces a few hours after assembly. Some seem better than others, but none are "strong".
Questions
1. How thick should I spread the stuff? Right now I am putting down one coat on the foam followed immediately by a second coat. Should I put one coat, let it soak in and cure (~10 minutes), and then a second coat?
2. I am using a foam brush - should I use a bristle brush to apply more adhesive?
3. How important is clamping? When I assemble the seat, it may be difficult to get a strong "clamp" while not distorting the thick foam and seat cover.
Thoughts and suggestions are appreciated!
Thank you,
Questions
Thank you,
Hi Guest!
