After several days of thinking hard about this while I had to go to my "other" job, I got back to work on the car and tried a few things. After a while I had success! It started on the first turn of the crank! But now I'm still confused.
I thought the culprit was the plastic washer between the condensor and the retaining nut on the points. The picture ncbugeye had really helped and I noticed that the P.O. did not have the plastic washer there at all, but had a steel one. After putting it back to gether it didn't start.
I then forced the screw off the points and repaired it with JB Weld, and then put in new points, condensor, and cap. Again no luck.
O.K., so now is where I'm confused and you are probably going to laugh at how stupid I am, but I'm tough, so here I go. I was moving the wires around on the cap, and tried #1 in the 7 o'clock hole. It would crank easy for one turn, then stop abruptly. I then kept rotaing the wires around the cap (which I have done 2 times in the last 4 days) and lo and behold it fired up when the #1 plug was in the 4 o'clock hole. O.K., stop laughing and please tell me how this is possible and what I missed. I static timed at TDC and the rotor pointed to the 1 o'clock hole like it should. My dizzy is fitted with the vacuum assembly tilting slightly forward, like I've seen before. I had an MG in the past and #1 was in the 1 o'clock position just like I was used to. So I don't know.
So there you go. I have exposed myself to the forum for the generations to come. So tell me, am I crazy and doomed to a lifetime of chuckles when someone falls on this thread during a search, or am I on to something strange?
Please be kind...I now reluctantly hit submit...... /bcforum/images/%%GRAEMLIN_URL%%/frown.gif
