Man I love that color- especially as it ages. (Don't know how to spell "patiniates")
Start at the water pump and count back. Between 2-3 seems to be the most common HG failure location.
I chose to build my own leak down tester. I opted for the 2 gauge configuration. With it, all you do is supply a bit more than 100 PSI to the tester's regulator, dial the regulator output to 100 PSI, and read the downstream gauge after the inline .040" orifice. There are no other adjustments.
