TR2/3/3A Commission Number Plates Stamps
K
kindacreeky
I am trying to make a reproduction commission plate for my Triumph Italia (TR3). The font of the stamped numbers and letters is an odd height. I tried 5/32" Hanson, but they were a bit too tall. The original figures measure 4.85/32" (0.152") or 3.85mm tall. I am guessing that Triumph Standard used these special height characters so that they could not be exactly duplicated. Does anybody know for sure? The fonts match vintage sets from a UK brand named "Imperial". The 1 has no bottom. The 3 is flat top. The 4 is closed. The 5 has a curved top. If anybody has a set of these special stamps, I need to possibly borrow. I am trying to help a bunch of Triumph Italia owners with this issue. If they are special, possibly only a Triumph collector would have a set.
For the Italia, there were three variations of the Commission Plate. One said 1120 KILO (no period). One said 1170 KILO. (with period) and has (1959) in the manufactured line. The third has the same 1170 KILO. but has abbreviations in the CO. and LTD. (TSF cars)
The font for the letters and numbers is the problem. We can have the plates properly etched and blanks made. We need the steel stamps to stamp the numbers and letters on the blank plates. The font is unusual and the height is odd. I found a set of stamps on ebay that had the correct font, numbers only. A vintage set made by Imperial in the UK. Here is a pic. it has long top on 1, also no bottom on 1. 3 is flat top. 4 is closed. 5 has curved top. 7 has curved diagonal (not unusual).
If you are a real perfectionist, the originals are not etched. The background is painted, but the lettering is raised and polished through the paint. I can look at one in a second and tell you if it's an original or an etched repop. (In your pictures, the first is a repop, while the 2nd and 3rd are original) Or...another way to look at it...if you cannot get the original raised lettering for the plate, why worry so much about a few fractions of a mm for the stamping?!?
PS, the first is confirmed as a repop in the screw used to fasten it. Triumph used larger style pop-rivets. It can be tricky, as many of these cars are in their 2nd or 3rd restoration, so even the repop parts look patinaed like an original would. I made this thread on restoring your original...but photobucket makes it difficult to see.
For the Italia, the plates were attached with screws. Not all had the same type screws. None had rivets. My car (#184) had the plate attached like the first pic below, with the interior trim type countersunk washers. The L meant Left. The CO meant Chassis only as chassis' were shipped to Italy for the Italian body. If there was a second O, with a space before, it meant Overdrive. The second plate shown is from Vignale car number 3, one of the show cars. It's plate just says C with no O. My car has had the plate modified. The previous owner cut off the bottom of the plate below where it says "Manufactured By". Not sure exactly why, but one of his buddies told me that he would claim the car was a Maserati. That's why I would like to get the proper stamps for marking the chassis number. The car shown is Vignale #235 just completed in the UK.
I just noticed that one of the pics in the previous post used Phillips screws to secure the plate. That is not original. The Italia had almost no Phillips type screws used. (found 6 securing the dash below windscreen) Almost everything slotted, metric of course in the body. Chassis straight TR3.
An interesting aspect of the Vignale-made Triumph Italia was that the body was stamped on the top of the inner fender well with the chassis number. This is usually covered with the goopy undercoat that covered all of the engine bay. It was not discovered that this number was on all Italia bodies until about 2016. The number is preceeded with the Greek letter Phi, and then ended with another Phi. Example in the pic below.
This car had lost its Commission Plate but this number will allow proper re-creation.
