Cold galvanizing zinc spray
stinky60
I just purchased a mild steel tailpipe for my Healey I thought about using this coating on this any thoughts, ideas what I should use? Thanks Bob
TomMull
I had a friend who used it on boat anchors. He loved the stuff but it was zinc paint as far as I could tell. Any paint hat will stand the heat will prolong the appearance of e3xhuast parts so the cold galvanizing should work as well as paint (I haven't checked it's resistance to heat). I did my BMW muffler in high temp black more than a year ago and it's still black with no visible rust. However, it's only preserving the appearance as the exhaust corrodes from the inside out, at least that's my experience.
Tom
John Kuzman
I have had excellent results with this stove paint. Used it on a header and complete exhaust system three years ago and still looks the same today.
https://www.stovepaint.com/
PAUL161
We used cold galvanizing spray to touch up galvanized bolts on exposed steel beams for buildings. It worked great, but if it got hit with a torch, it would blister. The stove paint that Mr. Kuzman mentions is a cost savings and reliable finish. It comes in various colors also. PJ
Platinum
LPS used to offer a good product, no clue if it still exists.
S
stinky60
Just sprayed the tailpipies last night with industrial zinc coating ,not on the muffler or down pipies will see what happens,just don't want to see the new pipes rust, went on good and even, I know sprayed it heavy in some places it didn't run
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 3
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
F TR6 Pegged out hot while cold Triumph 7
B Cold Start Problems BN7 Austin Healey 21
RAC68 Cold Air Bilge Blower update Austin Healey 13
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
N Running Cold Austin Healey 12
M Cold start problems Austin Healey 33
D it's cold and i'm bored... waiting for parts... Austin Healey 11
M Starting from cold Austin Healey 2
F TR2/3/3A Starts Cold, Not Hot Triumph 12
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
R Very Difficult cold weather starting problems! Austin Healey 21
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
M BN1 - Question about cold air box Austin Healey 6
K Hard Start, runs poorly when cold Spridgets 10
C Brakes pull to left - especially when cold. Where to start??? Austin Healey 11
S Hard starting on Webers from cold Austin Healey 12
Lutz Kramer Problem starting the cold engine Austin Healey 16
TRMark TR4/4A Cold air intake system Triumph 1
K TR2/3/3A Anyone running a cold air duct to the carbs? Triumph 15
drooartz MGB Must be the cold -- MGB will have a nice Xmas MG 7
M running cold Triumph 8
J Cold Starting on a Series II Jaguar 5
Morris Cold Air Intake Spridgets 2
N Cold Plug site shutdown! Other British Cars 19
tahoe healey How cold would you drive? Austin Healey 16
V hard start when cold Austin Healey 7
aeronca65t TR2/3/3A TR3-cold tires Triumph 2
H Cold blooded animal Triumph 21
nevets OD sluggish when cold Austin Healey 15
S Cold Start issue MG 4
tweety Cold Start thoughts Spridgets 6
D cold air duct 100 Austin Healey 3
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
drooartz A great [cold] drive today Spridgets 5
PAUL161 Just Brought "B" Out Of Cold Storage! MG 14
Morris Cold Start reality check Spridgets 10
theleisure Cold Weather, Oil Pressure Spridgets 10
T 100M Cold Airbox Filter Austin Healey 29
Thor Suggestions for hard starting 1500 when cold Spridgets 5
S Jag barely runs in cold weather Jaguar 7
T 1098 valve clearance - .012 cold? Spridgets 1
J 1985 Jaguar XJS - Cold start problem, help needed Jaguar 24
D Oil burning at cold start Austin Healey 17
zimmy quicker cold starts Spridgets 5
AH100M 100m/100 Le Mans Cold Air Box grommets Austin Healey 5
kodanja Cold starts? Triumph 24
RickB Cold weather and oil viscosity? Spridgets 8
