Just took posession of a 61 BT7 tri-carb which I've taken for a couple of quick spins and everything seems fine. Opened up the hood to do some cleaning and noticed that there is a loose wire with a connector at the coil. There are two wires already attached to the coil (plus the main wire to the distributor). Any idea what this is and if I should do anything?
Thanks,
Thanks,
