Coil Wiring
nov
Just took posession of a 61 BT7 tri-carb which I've taken for a couple of quick spins and everything seems fine. Opened up the hood to do some cleaning and noticed that there is a loose wire with a connector at the coil. There are two wires already attached to the coil (plus the main wire to the distributor). Any idea what this is and if I should do anything?
Thanks,
Dave Russell
Yoda - R.I.P
Originally there would be two white-black wires on the distributor side of the coil. One wire to the distributor, one wire to the battery cutoff switch in the boot, which also grounds the points when the switch is "off".
I would find out where the "other" wire goes.
The other side of the coil would have two white wires. One wire to the ignition switch, one wire to the nonfused side (source side) of the 35 amp fuse.
S TR2/3/3A Coil wiring Triumph 4
wingsandwheels MGB 1979 MGB coil w/ altered wiring MG 6
Griz Coil Wiring Austin Healey 4
Y MGB 1977 MGB Ignition Coil and Wiring. MG 5
Scotsman TR2/3/3A Coil wiring Triumph 12
W TR6 tr6 74' coil wiring Triumph 2
W TR6 74' tr6 coil wiring Triumph 8
C Coil to Distributor wiring? Triumph 10
R wiring hookup for coil on BJ-7 Austin Healey 1
tosoutherncars Quick question - 1500 wiring for coil Spridgets 7
L Spitfire Bit confused by my Spitfire coil wiring... Triumph 10
jsneddon Ignition Coil Wiring Triumph 2
B 79 Midget Coil Wiring Spridgets 18
G Ignition / Coil Wiring Question MG 12
C Coil Wiring Triumph 11
hawkwind Coil wiring Spridgets 10
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
longbridgehealey Coil terminals Spridgets 1
P TR3B Coil Issue? Triumph 7
A Wedge Won't fire without jumper from coil to battery Triumph 6
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
JPSmit female spade tab - coil Restoration & Tools 13
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
Lin Lucas coil question Austin Healey 8
K What to do for coil bracket on upgraded generator? Austin Healey 8
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
JPSmit Daughter's VW - coil pack? Other Cars 2
S Intermotor or Lucas Sport Coil ? Austin Healey 14
FlyingCat Spitfire Spark to Coil Triumph 23
S TR2/3/3A Front coil spring recommendation? Triumph 7
S TR4/4A Coil-over suspension upgrade Triumph 4
JPSmit Bosch Coil question Spridgets 14
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
2 TR2/3/3A Coil issues Triumph 31
D coil spring finish Austin Healey 5
M TR4/4A Front coil springs.....Rating & Length? Triumph 1
M TR4/4A Rear coil springs for TR4A Triumph 4
Marla TR4/4A Pertronic coil Triumph 12
M TR4/4A TR4 front coil springs Triumph 0
M TR2/3/3A Why is my coil so hot? Triumph 6
Marvin Gruber Big healey coil springs Austin Healey 7
M Starter field coil for BN1 Austin Healey 17
KVH TR4/4A Front Coil Spring Spacers Triumph 1
JimTR4 TR4/4A Coil - easily confused... Triumph 6
T TR2/3/3A coil mounting bolt oil leak Triumph 2
2wrench TR6 What's for dinner? Fried Coil??? Triumph 4
2billydavies TR2/3/3A dead battery... until i disconnect the wire from coil to distributor Triumph 10
J TR2/3/3A TR3 coil spring height Triumph 4
2 TR2/3/3A TR2 Coil choices Triumph 5
