Clutch to flywheel bolts
drooartz
I was prepping my project for tomorrow, and noticed that the clutch to flywheel bolts are the same thread and length as the spring pan bolts I just bought. The new bolts are grade 8, and the same length as the original bolts that came off the clutch when I removed the one.
Are these grade 8 bolts good to use for this application? Not sure about which grade should go in this application -- I've got a bunch of these on hand, so I'd like to use them if they'll work properly.
Should be fine.
drooartz
drooartz
Thanks, Trevor.
Sarastro
Grade 8s are probably better than what came on it originally.
You've got something like a maximum of 65 lb-ft of torque at--what--about a 4" radius, so the force on the bolts is about 200 lbs, max. If your engine isn't stock and you've increased the engine output even 50%, it's still only 300 lbs. Not terribly severe service.
CJD TR2/3/3A Clutch/Flywheel Bolts Triumph 28
K TR2/3/3A Torque value for TR3 clutch cover to flywheel bolts....... Triumph 2
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
B Clutch disc - which side goes towards flywheel? Austin Healey 8
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
R Clutch plate stuck to flywheel Triumph 20
T tilton rally clutch with aluminum flywheel Triumph 17
R_Lyle Replacing clutch / flywheel procedure Triumph 12
M TR4/4A TR4A Clutch on a TR4 Flywheel Triumph 3
M NEW / Flywheel/ Clutch slips...HELP Triumph 5
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
K TR2/3/3A Clutch Master Cylinders? Triumph 1
