TR2/3/3A Clutch through out fork misaligned
DavidApp
I am about to install an OD transmission in my TR3A and to speed things up a bit as well as insuring everything was good in the clutch area I got a new clutch operating shaft and clutch operating fork.
I added the extra screw to help prevent the locking pin from shearing. When I try to fit the release bearing assembly with the locating bolt in the gear box casting I found that the fork is offset by 1.5mm so I can not
install the release bearing assembly.
I see my options as Call the place I got the parts.
Remove 1.5mm from one side of the fork.
Move the locating slot over 1.5mm.
Any other ideas?
David
CJD
Interesting. I have always had enough play that the fork will tap each side of the carrier as the rod slides back and forth. When you say “locating slot”, are you talking about the one for the fork or the one on the end of the shaft on the pax side? If it is the slot at the end of the shaft, then I consider that redundant anyway. I personally would have no problem leaving it out, as the fork will keep the rod centered.
DavidApp
Hello John
Yes I am referring to the bolt on the Pax side. I did wonder about the reason for it as the fork prevents the shaft from coming out. The spring on the clutch side would tend to bias the fork into the through out assembly.
I may leave the bolt out.
David
Sarastro
I don't see the regular locking pin in your photo. The extra screw (I used a taper pin) is in addition to the regular, square-headed pin, not in place of it, and the regular pin should locate the fork on the shaft. If you insert it, do you still have the problem?
DavidApp
I did use the square headed pin to locate the fork before I added the second screw. I had not install the screw that locates the shaft in the gearbox casting when I first installed the tapered square headed pin. When I went complete the assembly, everything tight and square pin wired I found I could not get the screw in the passenger side of the casting that locates the shaft.
I had removed the locating pin when the photo was taken as it is difficult to get the through out assembly off with it in place.
Still have the problem.
David
Graham H
David,
I have seen this problem on another Forum and from memory the problem was with the new shaft, either the taper pin or the locater slot is in the wrong place. Leaving the locater pin out shouldn't be a problem, I have a box out of a TR6 and it doesn't have the locater pin. With a locater pin the anti rattle spring would be of very little value so you are good to go without the pin.
Graham
CJD
David,
Graham
+1...I was going to mention that the outer locating bolt was later removed by Triumph.
Sarastro
I had a similar problem with a new shaft that I bought for my TR4A. When the locating/retaining bolt on the right side was installed, the fork wasn't centered. I suspected that the shaft was designed for a different car (TR6?) and there were minor differences in the later transmissions. But the error was greater than the 1.5 mm you are seeing; it was more like 5 mm, if I remember right.
That's why I suspected that the drilling for the new bolt might just be a little off. If the original pin were installed, that would tell you for sure if there is a problem with the shaft.
charleyf
Bronze
David,
I encountered the same problem a few weeks ago using a TR6 tranny with a TR3 clutch setup. As John says the locating bolt on the pax side is the problem. I found that changing the bolt from the 5/16" to a 1/4" with a nut on the end gave me enough room to move the shaft and allow the TOB carrier to function on the input shaft cover. Interesting that it could also just be left off.
charleyf
Bronze
Not a favorable result. The pin for the fork is offset ( not centered) and would therefore not allow even a close fit.
DavidApp
I am going to go with no retaining bolt on the Passengers side as it seems redundant any way.
Is there any issues with the grease coming out of the bolt hole if you fit the grease zerks?
David
Graham H
My 6 box doesn't have grease nipples for the clutch shaft, Triumph must have relied on oil leaks for lubrication?
Graham
sp53
Glad you are getting David; I will be following close because I have no experience with OD and one day I will get mine up and going and I can learn from you. I would think a proper amount of grease would help lube and help seal the area.
steve
charleyf
Bronze
If you use a 1/4" bolt with a washer on each side of the tranny box and a nut you will effectively close off the hole and prevent grease getting out or dirt getting in.
DavidApp
I did the smaller diameter bolt.
Having contacted TRF about this problem Albert got back to me and said they were looking into it.
Great service from TRF.
Thank you.
David
T TR4/4A TR4A Through 6 Diaphragm Clutch Triumph 12
T 100-Six Clutch Recommendations Austin Healey 3
J TR2/3/3A clutch driven plate Triumph 1
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
G 79 Midget Clutch issues Spridgets 9
S TR2/3/3A Clutch not releasing Triumph 10
K Missing spring clutch release lever Other British Classifieds 0
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
T Clutch or Overdrive Slip Austin Healey 8
mt10flyer TR2/3/3A Clutch cratered - precautionary tale Triumph 0
BobHaskell For Sale: Clutch Slave Cylinder Bleeder Extension Austin Healey Classifieds 9
T TR2/3/3A Clutch Pushrod hole location Triumph 4
Jeepster Clutch Pedal Position Austin Healey 4
Basil Electronic Clutch [Deleted] Other British Cars 9
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
M master cylinder brake/clutch Tr3 Triumph Classifieds 6
Healey Nut Clutch problem Austin Healey 5
B TR6 TR6 1976 Clutch Choice Question Triumph 3
R TR2/3/3A Tr-2 Clutch Problem Triumph 46
M TR6 clutch adjustment Triumph 4
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
C BN1 Clutch Pedal Rattle Austin Healey 2
P TR6 Clutch problem not solved Triumph 6
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
R Clutch Hydraulics Spridgets 4
Michael Oritt Clutch Disengagement Austin Healey 15
P TR6 Clutch hydraulics Triumph 6
RJS TR4/4A Variable Clutch Engagement Triumph 1
B Flushing brake/clutch Austin Healey 16
G TR6 Binding Clutch Pedal Triumph 5
P TR6 New front shocks & air in clutch Triumph 15
J Clutch and Grinding Gear Austin Healey 12
M TR6 Clutch Hose, SS Vendors Triumph 2
M TR6 Clutch Master Rebuild: That Crazy Wavy Washer Triumph 1
D TR2/3/3A clutch/brake pedal question Triumph 4
longbridgehealey Clutch fluid Spridgets 7
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
Drone Dog Clutch Master Cylinder Leak Austin Healey 20
Jim_Stevens TR2/3/3A Clutch slave hydraulic line Triumph 1
longbridgehealey Clutch return spring Austin Healey 7
PeterK TR2/3/3A Dang! Clutch slipping in 5th Triumph 18
R TR6 Clutch issues Triumph 7
S TR2/3/3A Clutch cross shaft bushings? Triumph 5
S TR2/3/3A TR3 clutch release bearing... from Home Depot? Triumph 12
S TR2/3/3A Noise from clutch area? Triumph 20
tahoe healey DIY Extension for Clutch Bleeding Austin Healey 23
P TR6 Clutch pedal click noise Triumph 2
R Clutch Went Away Austin Healey 9
A Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
