On a recent road trip my aging Girling Slave cylinder started leaking at the back end. It drained the reservoir to the point where clutch would not disengage. Managed to obtain some Dot 4 and topped up. Did not have to bleed it but some pumping pushed what air was in the system through the leaking area. Managed to make the long drive home in 4th with overdrive. Ordered a new slave and SS flex hose from the usual supplier. Did the install on a friend’s hoist which went very well including the bleeding process.
Have driven about 400 miles on the new Slave Cylinder, but had to do subsequent bleeding a few times during that period. Replaced the copper washer in the new flex hose, no indication of leaking at any connections from reservoir and master cylinder. It appears that the new slave cylinder has failed. Subsequent bleeding while on the road gave a “frothy” appearance to the Dot 4 at the bleed nipple. During the bleed process there were brief periods where there was descent feel to the clutch pedal but that was short lived. Pedal goes to the floor now with literally no resistance. Flat bed to home.
The original Girling body is sitting on my bench with a repair kit beside it. Have not ever done a rebuild. Advice on the symptoms of frothy Dot 4 and doing the rebuild would be appreciated.
Frank D…
Frank D…
Hi Guest!
