with Geo..... makes perfect sense.
with Geo..... makes perfect sense.On a Stag, it doesn't come out through the interior (no removable tunnel), so it has to come out the bottom.Geo Hahn said:Sure, and the guys who climb Mt Everest mostly go up 'the easy way'.
71MKIV said:I know from experience, (not on my car thankfully) that missing tw's will result in no clutch release, and experience on my car, the clutch released but made awfull noises.
Well GEE, on a Triumph 10 sedan or wagon, technically the ENGINE doesn't even come out from above. Actually, it's just possible to do it from above, but it's generally felt to be easier to do it the factory way: raise the front of the car, unbolt and remove the front suspension subframe, and then lower the engine out the bottom!TR3driver said:On a Stag, it doesn't come out through the interior (no removable tunnel), so it has to come out the bottom.
I had a FWD Chevy that was the same way. Either the gearbox alone, or engine+gearbox could be lowered out the bottom, once the subframe was out of the way (and the engine suitable supported if removing only the gearbox).Andrew Mace said:but it's generally felt to be easier to do it the factory way: raise the front of the car, unbolt and remove the front suspension subframe, and then lower the engine out the bottom!
Gliderman8 said:Just checking the obvious...
Have you checked the hydraulic fluid in the clutch master cylinder?
Are there any hydraulic leaks under the clutch pedal?
No fluid=no pushrod movement.
