car was garage kept. So I got my car staretd but when I push the clutch it won't shift. I forced a shift and wow it kicked in. So the clutch feels like it was "empty". I opened the hood and saw(forgive me i am a neophyte to this) the round white plastic container that if you are looking at the front of the car is right in front of the driver's side. I am pretty sure this is a reservoir for the brake fluid. I open it and it is full, but the fluid looks a little black-ish in color. So I open a white plastic cap right next to this (about 1.5" wide I guess) on a metal container, smaller than the other container. I assume this is the clutch slave cylinder??? It looked empty. So, do I fill this container with fluid? if so, what? I thought I understodd it as Dot4 brake fluid, but am not sure. Thanks in advance for the help!
Lou
Lou
Hi Guest!
Do not ever get under a car on a jack! You can find a good pair of jack stands for under $20. Place those under something solid (chassis and not moveable suspension parts) and it is safe to crawl under.
