clutch master
10musketeer
I'll admit I havn't done much research, but thought I'd ask here first.
The other day I had trouble getting the gearbox into first, until I pumped the clutch several times. I immediately thought master. I don't have any experience with the clutch master, so does this sound right? I noticed that during the drive the clutch seemed lower than normal, but the more I used it the more it seemed to return to normal.
What should I look at first?
And look up under the footwell at the M/C for tell-tale fluid leaks at the actuator rod "boot".
Check your shoes for brake fluid spots.
