Maybe this is common knowledge, but I was trying to remove the tapered pin from the clutch fork on my BT7. I ground the protruding end of the pin flush inside the bellhousing and then attempted to use a punch to bang it out. That didn't work. I then was curious what the brass screw was for on the end of the clutch shaft. The designers must have realized the difficulty of removing the tapered pin and provided a long threaded hole to use as a pulling location. I used a 1/4-28 grade 8 bolt and a short length of appropriate size pipe with a washer and used the affair to pull the shaft out of the fork. Turns out the tapered pin is dead soft and will double shear with about 1000 pounds of force, of which a 1/4 inch bolt can easily generate. The remaining pieces in the fork were then just punched out with it clamped in a vise.
Hi Guest!
