Clutch Fork Pin Removal
dezand
Maybe this is common knowledge, but I was trying to remove the tapered pin from the clutch fork on my BT7. I ground the protruding end of the pin flush inside the bellhousing and then attempted to use a punch to bang it out. That didn't work. I then was curious what the brass screw was for on the end of the clutch shaft. The designers must have realized the difficulty of removing the tapered pin and provided a long threaded hole to use as a pulling location. I used a 1/4-28 grade 8 bolt and a short length of appropriate size pipe with a washer and used the affair to pull the shaft out of the fork. Turns out the tapered pin is dead soft and will double shear with about 1000 pounds of force, of which a 1/4 inch bolt can easily generate. The remaining pieces in the fork were then just punched out with it clamped in a vise.
dezand
That is interesting, for my car the pin was installed from the gearbox side. Trying to pound it out from the bellhousing side did not work.
Another guy who restores Healeys said he usually drills them out, but sometimes the drill wanders and ruins the fork.
Once I figured out the puller method it took all of 30 seconds to remove the shaft with the bellhousing still attached to the gearbox.
Jack T
Excellent information. Wish I had known this a couple years ago when I was trying to remove mine. I suppose that new parts will go together and come apart as designed, but when dealing with something that's been in place for 60-odd years all bets are off. I gave up and re-assembled with the fork still in place.
Rob Glasgow
Jack, I did the same thing after fighting to remove the pin for some time. I would have liked to replace the bushings, but gave up and said I’ll do it next time I have the transmission out. In 25 years or so…..
KVH General Tech Clutch Fork and Broken Pin Triumph 8
Lukens TR2/3/3A Clutch fork pin. Triumph 9
J TR6 TR-6 Clutch Fork Taper Pin-Torque ? Triumph 5
hondo402000 TR6 New TR6 Clutch shaft, fork and beefy pin Triumph 3
Banjo The dreaded broken clutch fork pin! Triumph 9
heliguy The dreaded clutch fork pin again..... Triumph 9
tomshobby clutch shaft/fork pin Triumph 8
I Broken clutch fork taper pin Triumph 6
M Clutch Fork Pin Triumph 4
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
D TR2/3/3A Clutch through out fork misaligned Triumph 17
M Clutch fork lever Austin Healey 11
T Clutch Fork removal/rebush Austin Healey 3
J Clutch fork free play on BJ8 How Much? Austin Healey 13
S TR2/3/3A remove a clutch fork Triumph 1
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
K Clutch fork fix Re: the 1/4" bolt repair. Triumph 10
KVH Clutch Fork Lock Wire Triumph 1
J TR6 TR-6 Clutch Fork Cross-Bolting ? Triumph 2
KVH TR4/4A TR4A Clutch Fork and Shaft Triumph 37
dondel Clutch Fork movement & Master Cylinder Austin Healey 13
J Clutch Fork Clearance Info Request Spridgets 2
CCURTISS T-Series Extra MGTD/TF Clutch Actuating Fork???? MG 2
GT6_Mark T-Series MGC Clutch Fork Question MG 1
CCURTISS TR4/4A TR3/TR4 Clutch Fork Install Question Triumph 8
heliguy TR5/TR250 TR250 clutch fork "pins" Triumph 2
B Clutch Fork Austin Healey 3
B Clutch fork shaft rebuild. Austin Healey 9
martx-5 Gearbox Clutch Release Fork Triumph 2
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
