Clunk noise
:iagree:
So are the high quality Marine stores omly stocking that China crap its all about the bottom line.---Keoke-- :hammer:
I buy (nominal) Grade 5 or 8 nuts, bolts and washers at OSH. I haven't checked for any 'Made in' labels on the packaging, but I have always wondered if I was getting quality fasteners. I think you just have to go by the label and hope for the best; I suspect even McMaster-Carr and others may be sourcing from China or India, etc. At any rate, I haven't had any fail on me (yet). The bolts on the shocks--the rear ones, at least--aren't what I consider critical. I use Grade 8 flatwashers almost everywhere I need a flatwasher because they are less likely to deform and, well, they're cheap insurance.
If it makes you feel any better, there has been a problem with counterfeited aerospace fasteners. Some of the critical, 'yellow-tagged' fasteners--like the ones that hold wings and engines onto the aircraft--can cost hundreds of dollars apiece. It's tempting--and too easy--to substitute an automotive quality--or worse--fastener for one of the 'special' ones. I just try not to think about this too much.
BOB!!!
I just did a shower stall in an expensive home. I had specified to the wholesale plumbing outfit I wanted all top grade SS for the assembly screws, drain covers,soap dishes and support bars. When the items arrived they were blazoned with "STAINLESS STEEL" on the box covers . In very small print was a list of countries where the items were made one country was China , as i took my magnet out of my pocket all the items jumped on to it and clung. I sent it all back and told the supplier send me ss and they did. Interesting too the invoice price did not change .---Fwiw--Keoke
That's a good test for stainless--at least for material--but unless you have the ASTM testing equipment I don't think you can tell if you're getting quality Grade 5/8 bolts. I wouldn't use stainless for any critical fastener on a car (I've got stainless exhaust manifold-downpipe studs and they seem to snap easier than the ancient mild steel studs I had in there before).
If you can't get what you need locally, I've ordered from here before--service was good: https://www.boltdepot.com
Useful chart here: https://www.boltdepot.com/fastener-information/Materials-and-Grades/Bolt-Grade-Chart.aspx
John_Progess said:
Just remember that grade 400 SS is magnetic and grade 300 (304,316, 310 etc) are not magnetic. Just a thought and have a good day!
John
Stainless markings vary.
Most stainless is non-magnetic.
Usually stamped A-2
tahoe healey said:
Thank you for that chart. Is there a comparable nut marking and chart?
Never seen one (doesn't mean there isn't). As a general rule, use the same grade nut and flatwasher as the bolt grade. Again, I usually use grade 8 flatwashers unless it's inconsequential because, well, plain steel washers are pretty much worthless.
Okay, I acquired the grade 8 nuts, bolts and washers. Has anyone tried using some blue lock-tight on the washer to frame to prevent any movement? I intend to use lock-tight in addition to the lock washer.
Again, thanks for all the advice.
TH
One more question, can grade 8 bolts be cut to shorten them or will that effect the strength as in case hardened material?
Yeah TH, you can cut them just make sure there are at least three full threads showing outside the nut after tightening.--Keoke
I use grade 8 flatwashers under the bolt head on the shock side and lockwashers on the chassis side. Here's the reasoning (using 'random' numbers--not actual calculated--to illustrate the principal):
A given bolt at a given torque produces, say, 10,000psi of tensile (clamping) force. If the area under the bolt head is (ex. only) 1/2" sq, then the clamping force applied will be 5,000 pounds (0.5in sq. X 10,000psi--the square inches 'cancel' out and you get the 5,000 pounds). If you put a rigid washer under the bolt head that increases the area to 1" sq, you increase the clamping force to 10,000 pounds. That's why you use a grade 8 flatwasher: to increase the area of the shock that is clamped by the bolt while not releasing pressure by deforming. In addition, since the shock body is some sort of crummy aluminum/(zinc?) alloy, the flatwasher prevents the bolt head or, worse, a lockwasher from digging into or compressing the metal and releasing the pressure. Grade 8 flatwashers just fit in the recess around the bolt hole on the shock.
This is one of the few times I've found that using a split lockwasher works well (note that lockwashers are not used under head nuts or bolts--it's not a coincidence). Threadlocker won't hurt, but if you torque the bolts properly--35ft-lbs IIRC--they should hold. If not, you have other problems.
If you end up cutting the bolts--a cutoff wheel works best (you'll be all day with a hacksaw)--put a die or at least a nut on the bolt first so when you remove the die/nut you'll chase the threads. Otherwise, you probably won't have a decent 'starter' thread on the bolt.
Perhaps I missed it in this thread, but don't you folks use loc-tite or similar brand thread lockers? Ny-loc (plastic insert) nuts are pretty good, but there are also the crimped or high-temp slotted self locking nuts that are used for non-cotter keyed installations that work very well. Look at the Aircraft Spruce catalog on line for a good cross section of what is available. I also had the exact same clunk and now use the internal wrenching bolts, nylon insert nuts and loctite.
