Tech Talk: Throttle Linkage by Fred Thomas |
..The picture and the write-up by Fred Thomas are different. The rear carb lever in the picture is outside of the mixture control rod fork (as on the front carb lever), and not in the middle of the fork as Fred Thomas says. Which way is correct?
Hi All,
I knew the correct way to hook up the front carb to the mixture control rod, but the rear carb connection has me confused. The picture and the write-up by Fred Thomas are different. The rear carb lever in the picture is outside of the mixture control rod fork (as on the front carb lever), and not in the middle of the fork as Fred Thomas says. Which way is correct?
Chuck Murphy
