I'm missing something; don't see anything on that page about TR4A having the OD on the right. What I see says the switch on the right is for TR4 only, (meaning not TR4A).tdskip said:TRF also references OD on the <span style="text-decoration: underline">right</span> for TR4a only;
https://www.zeni.net/trf/specials5.33/70.php
TR3driver said:I'm missing something; don't see anything on that page about TR4A having the OD on the right. What I see says the switch on the right is for TR4 only, (meaning not TR4A).tdskip said:TRF also references OD on the <span style="text-decoration: underline">right</span> for TR4a only;
I also see P/N 611974 listed for TR4A (not TR4), which clearly shows the OD switch mounted next to the turn signal switch. This is the same piece shown in the factory parts catalogue illustration that I posted above.
bgbassplyr said:Only have the two stalks described, one on each side.
Can't get to the shop to verify light switch location and will have to find the dash to verify. 4A has been reduced to it's many parts and they are stored here and there. Car was wrecked, frame bent so I reduced it to usable parts, chucked the remainder.
Check the text on page 8; I think you'll find the paragraph I showed earlier in this thread.HerronScott said:Unfortunately, they didn't include the overdrive switch.
Is there a hollow shift lever available in the TR4A pattern?DNK said:Tom, why not put the switch on the shift knob?
