Changing points makes me want to change cars...
[ QUOTE ]
I'm getting the points from Victoria British, and I don't even have to wait since I can go out on my lunch break and grab them (Lucky meee, I live work near Lenexa, KS)
Well, I don't know why you wanted to make two trips you could have gotten the Pertronix and saved yourself all that misery plus an extra trip.---Keoke /ubbthreads/images/graemlins/laugh.gif
Okay, I have a similar prob. to Van Halen, but not as bad. All I did was simply change all of my spark plugs, the wires, and the distributor cap. When I lifted the old distributor cap, I didn't want to mess with the points, etc. The car fired up better than ever, ran well for about five minutes, then started sputtering and completely cutting out on idle (it would cut out, then come back on in a split second). This never happened before. Could this be a case of me not putting the new wires in the correct order? Do I have to time the engine after doing these simple procedures? If I can;t figure this out, I'm taking it in. If I did put the wires in the incorrect order on the dist. cap, is it okay to drive a couple of miles? Please help. Btw, all of my old plugs were ashy and dark black. This car is frustrating me.
Re: Changing points makes me want to change cars..
Flum,
Why not go all the way and change your points and condensor?
If the car ran well for five minutes, you have the plug wires in the correct order, otherwise it would have run like a bad, er, tractor. Setting the points is really quite easy and condensors do go bad. Oh, and what about the rotor. Whenever I refresh my distributor components I always go with fresh everything. That said, where did you buy your components? (sometimes buying from mainstream vendors will get you ignition parts that may or may not work well. this rule of thumb doesn't always hold true.) Usually sticking to a popular LBC vendor should guarantee your getting quality parts. It is possible to get a distributor cap that will crack right off the bat, I have had that happen before. Take it off and look closely with a strong light. Is the rotor making unusual marks on the inside of the cap at the contact points? Underneath the rotor should be clean and not rusted. Check these things out and see what happens. Remember to make sure everything is clean and well seated and all connections are solid. Hang in there.
Bill
Hello all,
a few of my thoughts on this subject, it is sometimes easier to remove the distributor to a bench to fit points, depending on the model of car, particularly if setting them using feeler gauges. A basic, especially if you are not familiar with the car is to take careful note of how things come apart, orientation of distributor, leads, etc as it is easy to get mixed up, a little care early on saves a lot of time later.
The worst car I ever worked on was a TR7 with an AC Delco distributor in which the mechanical adavance mechanism was above the poits making changing and setting very fiddly. I replaced it with a Lucas unit from a Dolomite Sprint which is basically the same engine. Incidentally, why Triumph never used the Sprint engine in the 7 I'll never know as it is relatively easy to get about 200 bhp out of it. Who needs a big V8?
Alec
Bill and Piman-
Okay, you gave me enough courage. I changed the points and condensor. At first the car wouldn't start at all. So, I adjusted the points so that they were touching a portion of the rotor arm. The car started right away, sounded strong, but idled high (never done that). I'm totally new to this points and rotor arm stuff. I do have a tune-up kit from TRF (where I got the points and condensor), but I'm unsure about the rotor arm. How does this come off the distributor? The new one makes me believe it just basically pops off? Sincere thanks.
Rotors do just pull off, though if it hasn't moved in a decade it can get married to the shaft.
High idle may be caused by incorrect timing (possibly to much advance). Or, someone may have increased the idle in the past to address an ignition problem that you have now fixed. In any case you will want to set the timing anytime you change the points and only after you have the points gap correctly set.
For diagnosing ignition failures I always carry one of these (now even on sale):
https://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=4424
For setting the timing I use a cheap digital multimeter from Radio Shack that has an audible continuity beeper, others like a light bulb. Just set static timing by the book to get it running then dial it in by ear.
You can't go too far wrong replacing all ignition components then keeping the old ones as spares (unless they are know to be bad) as ignition may well be the most common roadside breakdown plus often the easiest way to diagnose an ignition failure is to replace parts with the spares and see what works.
Thanks, Geo Hahn. That tool does look handy. I did manage to pull the rotor arm off (a little corrosion on the shaft), and replace it. I am brand new to this, so really, I am just using my ear and feel when it came to adjusting the points. My totally novice impression was that the further the gap between the points, the car would hesitate to turn over, and sometimes wouldn't at all. So I closed the gap very close (almost touching, maybe even touching, is this bad?)) and it fires right up, and drives better than ever. However, my tach. doesn't work, but idle sounds a bit high (my oil pressure now at idle is 25). But, overall, this is a vast improvement, thanks to all of your help. Correctly adjusting the timing (other than my amateur ear and feel) does seem out of my league. (I don't even see the degrees' marked on the crankshaft!)Geo, you did mention too much advance. How is this adjusted? Just curious. Many thanks.
You must have a points gap for the engine to fire & run. I do not have a TR6 so I do not know how the timing mark on the pulley looks, there will be no degrees marked, just a pointer on the block at the pulley's 12:00 position and then a notch or hole in the pulley itself.
You need to adjust the points gap with the points riding on one of the high spots on the cam. Maybe you realize this but if you think you had the points touching and it still ran then they were not on one of the cams (high spots) of the distributor shaft. The gap you want will be in the manual and should be set with a feeler gauge though traditionally a simple paper match from a matchbook is about the right thickness.
I would explain more but it's like composing a narrative on how to tie your shoes... 10,000 words to describe something that can be shown in a couple of seconds. If there is anyone who can walk you thru this you'll be set for life. A good start might be the local British Car or Triumph club.
Tune-up procedures [was: Changing points...]
Hi,
[ QUOTE ]
Bill and Piman-
[/ QUOTE ]
You are correct, the rotor is easily removed. It just pulls off, upward. The new one pushes on adn will sort of snap into place. Just be a little careful because it's possible to break the plastic rotor and/or distributor cap.
I'm going to expand a little on ignition tuneup related issues, with some info you might or might not know and might find helpful.
There is some variance in specifications from one model of car to the next (so consult a service manual for your car), but the following is pretty widely applicable for most older points-style ignition systems.
In additon to the points and rotor, you might also consider a new distributor cap if you haven't already installed one. Over time and use, caps get cracked and develop electrical tracks or other problems that mess with the ignition. It's hard to see and diagnose some of these problems so for the cost is generally easiest to just replace the cap at the same time as the rotor and points.
Some tips when replacing the cap: It's important to keep them in the right order. So loosen the old cap from the dizzy without removing the plug wires (it's okay to remove the center, coil wire since that one is easy to remember). Decide the orientation of the new cap (usually a tab and slot on the cap and dizzy) and then temporarily reinstall the old cap and carefully transfer the plug wires from old to new, one at a time being very careful to keep them in the same order. If need be, number the wires and write the matching numbers on the cap where each wire re-attaches.
The newly installed points need to be gapped. I.e., the distance between the two points should be set to a specified amount measured with a feeler gauge, when the points are being held open the maximum amount (the rubbing block is on top of of the lobes on the shaft). Consult the repair manual for your car to get the specified gap.
The point gap should be rechecked after the car has been run for a short while, maybe 25-100 miles. The rubbing block tends to wear alot initially and that will allow the gap to close slightly. So it usually needs to be re-adjusted. It's also a good idea to check/adjust occasionally, say every 100 miles, since the rubbing block continues to wear over the points' lifespan.
Some replacement points' rubbing blocks have been reported to wear too quickly. A little grease wiped on the shaft where the rubbing block rides might help it last longer. Be careful, though, that there is only a smear or wipe of grease, so that none is spun off where it might foul the points or cause other problems.
The reason your idle increased probably has to do with the engine's ignition timing changing with the new parts installed. Consult a repair manual for your car's timing specifications. Commonly a timing light is used to set this, although there are other methods that will work pretty well, too. There is a clamp at the base of the dizzy that's loosened to allow the entire distributor to be turned to change timing. Many Triumph's also have a fine adjustment on the dizzy that makes it pretty easy dial in the timing more (or make adjustments on the road, for poorer or better quality gas, for example).
New wires can help an ignition system work a lot more efficiently, too. Generally, kits are available, but sometimes it's necessary to buy a "universal" set, cut to size. If that's done, just try to keep the wires as short as possible, but still allow some slight slack for a little movement of the distributor when setting the timing. Also watch the routing of the wires, that they aren't laying against a metal engine part that might rub or transfer heat to damage them and/or cause a short. And, plug wires are usually okay crossing each other at 45-90 degrees (like an X) but the high voltage current might jump from one to the other if the wires are lying closely parallel to each other (bundling with a zip tie might be a bad idea, for example). Just arrange them so that they aren't touching, if at all possible (and be careful to not change the firing order in the process), or only are crossing at 45-90 degrees to each other. If they must run parallel, many types of wire separators are available at most auto parts stores and can help prevent problems.
This is also a good time to pull the spark plugs and replace or clean them, checking that the plug gap is correctly adjusted. Here, again, it's easy to get the wires mixed up, so do one at a time. Just be a little careful to not cross-thread the plug in the cylinder head and possibly use a little anti-seize on the threads as well. This is available in small packets at most auto parts stores.
There is also a dielectric grease in small packets avalable at most auto parts stores. A small amount of this smeared on the inside of the plug wire boots will help prevent corrosion, keep water out and make the boot easier to remove the next time you do a tune-up. (This stuff is useful on many electrical connections, and even light bulbs around the home.)
Once all this is done, you might need to adjust the idle a bit and possibly rebalance the carbs.
Be sure to listen for any pinging or knocking in the engine that might indicate timing is over-advanced. Pinging and knocking can damage an engine pretty quickly!
All this is standard tune-up procedure for most older points-style ignitions. It's a good process for anyone enjoying driving an old car to learn. Besides these regularly replaced parts and adjustments, the main thing to watch out for is that the dizzy is in good working condition. Some possible dizzy-related issues include internal advance springs getting soft and weak over time causing incorrect advance, old vacuum hoses loosening or cracking and leaking causing incorrect advance and/or retard, and worn bushings in the dizzy inducing a wobble that messes up ignition timing.
Hope this helps!
Re: Tune-up procedures [was: Changing points...]
Everyone, true thanks. You gave me the guts to try it myself, and it definitley improved things. Thanks. a lot of the obvious stuff that you patiently point out, is brand new to me. Alan, extremely helpful tutorial. Everyone, very helpful. It's running better than ever. I did change all of the plugs, plug wires and dizzy cap, as well. Me and the Mrs. are lucky enough to have some vacation time without the little one. In a couple of months I'd like to take the TR6 to the Oregon coast (about 200 miles round trip) through a pretty narrow Cal. Redwood Forest highway (not a lot of turn-offs, and a winding road, yikes!). I'm going to have a mechanic give it a safety check in the next few weeks. He is an experienced (but almost too busy) TR guy. But, anything (weak points) I should ask him to really look at? Besides the obvious (brakes). Thanks.
[ QUOTE ]
[/ QUOTE ]
Hey, no "yikes" about it. It should be more like "yipee!"
I've driven that route several times and it's perfect for a TR! I bet you love it.
Twisty/windy is what sports cars are all about! /ubbthreads/images/graemlins/driving.gif
Hope the weather allows you to put the top down and really enjoy the "wind in your hair" (I always did, which might be why I have so little hair left now)!
[ QUOTE ]
[/ QUOTE ]
Yes, the obvious first safety check is the brakes. After that look at the tires, all the rubber hoses, drivetrain (especially things like thrust bearings, clutch, u-joints)), cooling system and lighting. Also, your mechanic will probably look over the rear trailing arms on an IRS car, along with the front suspension and steering. If he's experienced, as you say, he'll very likely have a good check list and can probably best advise you. There's nothing like having a good, knowledgeable set of eyes checking everything out closely, to help avoid problems later. Try to have any work done a week or two before departure, so you have time to drive the car a bit and be sure everything is 100%, in case any small adjustments or corrections are needed.
For the trip, you might want to put together a small emergency repair kit to keep in the trunk. Having just done a tune up, you now have spare used spark plugs, rotor, cap, condenser, points, etc., if you want to save the cost of extra new stuff (you also know that the old stuff was working at least somewhat well, before it was replaced). Also I like to carry an extra fan belt, cooling hoses etc.
You might check the BCF archives. There have been several lengthly previous discussions about putting together a kit of things that might be hard to find if needed while on the road. (It's not like touring in a late model Chevy, where there's a dealer in every other town and most auto parts stores have everything that might be needed in stock or in a nearby warehouse!). Helps to be prepared with a few things, "just in case".
On the other hand, I gotta say some of my best vacation time has been as a result of breakdowns on the road that forced me to stop and smell the roses while waiting for repair parts! In one case, that was 3 days in Port Orford, OR. If you happen to go through the town, check to see if the Whale Tail Restaurant is still there. It's worth a stop. I recall great service and wonderful food at bargain prices. At that time it was one of only two or three 5 star restaurants in the state of OR. There were truckers in plaid shirts and jeans enjoying their meal equally as much as the folks who arrived in limosines wearing evening gowns and tuxes!
[ QUOTE ]
...On the other hand, I gotta say some of my best vacation time has been as a result of breakdowns on the road that forced me to stop and smell the roses...
[/ QUOTE ]
And meet nice people too... such as the Tribal Officer who stopped to see if I needed any help...
Fortunately it was just a broken ignition wire and I was soon on my way. Enjoy the ride.
By now with all the advice you are probably way down the road. Jones said:
[ QUOTE ]
Also recheck that you installed the points right; that the wire and plastic insulators are on correctly. If not right it will not run, ie not spark.
[/ QUOTE ]
He is absolutely right. A common cause of problems after the points are installed is the accidental reversal of the steel and nylon/plastic fittings from the points and condenser. Look carefully at your manual or the Moss catalogue and you'll get it right. If you have it reversed the car will never start.
I just switched to a Pertronix this past weekend. In the past I always did my initial timing using the time honored method described in Haynes. This time I used a timing light and checked the timing at idle and noted it (about 8 deg BTDC). I removed the points, installed the module, and checked the timing again. It was off, but I simply loosened the dizzy clamp and set the timing to 10 deg. BTDC at 850 rpm. This is the same as static, but with no vacuum retard (gone) or advance(plugged),and at that rpm there is no mechanical advance, so the static is correct even with a timing light at low idle. The car drives great, no pinging. I might experiment with a little more advance.
BTW I found that I had to slightly grind the base of rotor. With the magnetic collar on the dizzy shaft the rotor is slightly higher. At idle I could feel something rubbing inside the cap. Evidently from the marks on it the rotor was pushing the carbon brush all the way up into the cap.
