carpet snap location drawing 100/6
neilert
Does anyone know where I could find a simple diagram showing the carpet snap locations for a 100/6. I have found several written descriptions, but it would be very helpful to have a drawing, photos, or diagram. Thank you- Neil
Hi, Neil - I can't help you, but I'm hoping somebody does. I'm starting to install the new carpet in my 100-6 tomorrow night, and I can find no visual reference for the snaps. I think it is four per section on the floor pieces, but I'm unsure of the trans tunnel (might glue it down on the tunnel). Good luck with yours!
Larry
Well Neil, I've never heard of a drawing illustrating where to install the snaps. I do have a suggestion though. Most I've seen put two snaps just in front of the seat pans for the front carpets and just behind the seat pans for the rear seat carpet. I don't think you should glue the tunnel cover down as it will get wet and you'll want to remove it. I put one snap each side of the tunnel near the back down low, it's held up real well at that location. I do have some suggestions on installing them. One, choose a location on the floor pans that is raised rather than recessed. you'll need all the height you can get to assure a smooth carpet. Also check underneath before you drill to make sure your not going to drill into the X bracing, the snaps won't screw into anything that thick.
Good luck
OK Johnny, There are two more snaps used on the front carpets. These are located just aft of the crease in the foot well. Actually if the original floor boards are there you should be able to find the holes knowing where to look.--Keoke
Hi, Keoke - My bad luck, not the original floor boards. :frown: But I thought there were four on each of the front sections. Do you know how many on the trans tunnel?
Thanks
Larry
longbridgehealey said:
Hi, Keoke - My bad luck, not the original floor boards. :frown: But I thought there were four on each of the front sections. Do you know how many on the trans tunnel?-
--I "Think" three on each side should do it. One at the forward edge and one at the back where the third one is located in the middle of those two on each side.---Keoke
Thanks
Larry
Sounds about right - I know there is a problem getting the tunnel carpet to lay down flat. I'll try six and see what happens...Larry
If anyone has the carpet out of their car, a few photos sure would help at all of the snap locations. I'd be happy to draw the diagram and post it for everyone.
While I know its Bj8, I would guess the carpet snaps would be in the same position for most models. Anway heres a few pictures still showing the snap base / screws in place:
tunnel:
https://www.austin-healey3000.com/apps/photos/photo?photoid=5122383
https://www.austin-healey3000.com/apps/photos/photo?photoid=5131333
right hand floor:
https://www.austin-healey3000.com/apps/photos/photo?photoid=5122408
https://www.austin-healey3000.com/apps/photos/photo?photoid=5125435
left hand floor:
https://www.austin-healey3000.com/apps/photos/photo?photoid=5125434
sorry none of the front of the footwells
might not be much help
cheers Andy
