healeyblue
All right guys, I am progressing to the installation of the carpeting now and while test fitting I was wondering about the correct location for the carpet snaps. Where are they located and how many per location. I read that the trans tunnel carpet is snapped in place, and the front floor pieces are snapped in. Other than those places are there any more pieces that will be snapped in place as apposed to glued in place. I seem to recall that the front floor pieces should have 4 snaps, is that correct? Where would these be? close to the 4 corners or more inboard? For the trans. tunnel I count 7 hole along the bottom of the tunnel on one side and 8 along the bottom of the other side. Would these be for the tunnel carpeting? It sounds like a lot but I would think it would take a lot to hole the tunnel carpet in place due to its shape and not being a flat piece. I have layed down dynamat over the entire interior prior to the jute padding. I have to put some on the tunnel sheet metal next but was wanting some input from the forum before I get too far. I will work on the side kick panels and furflex in the mean time.
JIM
JIM
