kennypinkerton
Dynamat Xtreme more than likely. inside door skins, floorpans, front and rear bulkheads. It has a little better sound dampening properties than the standard, and is temperature resistant over a much larger temperature range than the standard (from negative temps up to 300F). Should be fine even in the floor areas near the exhaust pipe. I'd probably still use a thin bit of padding for the carpets though.
