Carbs leaking oil
Coyote1
My Strombergs are leaking oil. I put new o-rings in and was careful not to overfill the dampeners but they still leak. Anyone have any ideas?
I need to ask first, how are you determining that the damper well is at proper level ?
dampeners were filled so that the plungers stopped 1/4 inch from the screw top.
I was thinking maybe they were overfilled..but no.
Ideas, no, not from me. The O-ring is the seal so unless you put the old ones or a wrong size back in instead, I can't see how oil is getting past it....unless there's a hole in the bottom of the adjuster
Just a thought: Could the bore have been chewed up so badly when you forced out the retaining washer that it damaged the O-ring on the way back in?
Any chance you put in the wrong size O-ring?
Maybe a hole punched through the adjusting screw? (No idea how that would happen, just trying to be complete.)
Otherwise, I don't see how it could leak, as the cavity is formed by a solid tube with the bottom blocked by the adjusting screw & O-ring.
Are they leaking until empty or does the level just seem low? If you still feel the resistance from the oil about 1/4" until the damper hits the threads on top it's ok regardless of the level you see beforehand.
Hi Larry,
Is this what you replaced?
Is it possible that the O ring you replaced yours with was smaller?
Cheers,
M. Pied Lourd
As Randall noted, it HAS to be getting past the O-ring. Either it's the wrong size or been compromised in some way.
This may seem silly on the surface of it, but: if the bore is burred, try using a bamboo chopstick, hacksawn with a slit and some 600 grit wet-or-dry... like honing a cylinder wall. Some light oil and patience. :wink:
<span style="font-style: italic">EDIT: Don't be tempted to use a drill. Do it by hand.</span>
Thanks guys, several good tips. I'm going to pull it apart and recheck everything. It seems so simple but I guess nothing ever is.
