Actually got the car to start...well, the key would not start the car, but the first click did activate the fuel pump and gauges. Had to push the button on the solenoid. Does this mean I need a new switch?
2nd problem: Once car started, fuel began to spew from under the front bowl lid. Took it apart, put back together, then spewed from under the rear bowl lid. I rebuilt both with Joe Curto's kits and the proper washer and screws are present. Could this be a float problem? I replaced the needle valves and adjusted the float. I thought the float/needle valve would prevent excess fuel entering the bowl. Any ideas? I'm planning to call Joe Monday.
