So I've got my newly rebuilt carbs (HS4) back and installed, and I've run into a problem. I can't get the idle down at all -- lowest idle I can get is about 1800RPM if I want to keep the carbs synced. I can lower things a bit by backing out the idle screw on the front carb, but the screw on the back carb is already all the way out -- won't lower any more at all.
Here's what I've done so far:
As an aside, when blipping the throttle (cables disconnected) it seems to take too long for the RPM to drop back down. Something sticking, maybe?
- Distributor just rebuilt by Jeff, back to points
- Plugs gapped to .025"
- Timing is 32* all in with vacuum disconnected
- Valves all set to .015" cold (most were already close)
- Needle is #5, jets currently set to .040" down
