Jim_Gruber
22 degrees in Dayton this AM time to get the Hardtop out for Bugsy.
1) Not a job to do by yourself unless you like scratching up paint. Bugsy is in Blue and Primer Grey so not big deal but an extra set of hands is needed.
2) Brackets were all FUBAR. Needed to remove and bend back into shape. Still getting the hold down brackets attached is a PITA. Two big screwdrivers from below helped to get alignment and that a 1/4" drive 1/2" socket allowed me to twist the bolt and get it to drop down so wingnut can be attached.
3) Top and Sidecurtains at the rear do not meet correctly and allow a pretty big gap. Any tips on fixing. Could be from Top not being cranked down tightly as PS big gap in back where hardtop meets the rear deck. A Rag or some foam will close that up.
4) I expected heater to blast me out and was to getting any heat. Can I assume Heater Valve rotated Counter Clockwise closes this valve and screwing in the valve Clockwise opens it up. The Heater box was cold so I'm guessing that's the issue otherwise some sort of blockage in my heater core.
5) Next up, Sunday AM installing that really loud horn I bought.
6) Back to separating the Bellhousing and replacing it on my 5 Speed Tranny.
View attachment 51216View attachment 51217View attachment 51218
