Bugeye Windshield Install - no sweat
TulsaFred
I installed a new windshield in the frame this morning. I had read many threads warning of the difficulty of this procedure. While I typically seem to run into as many or more difficulties than others when I do a project, I found this to be relatively painless.
I used the windshield and gasket from Moss, and both items were high quality and perfect fit. Kudos.
I used MacGregor's frame to body seal based on what I've read on this site. Slid into the slot on the bottom of the frame with little difficulty.
To install the windshield, I placed the gasket in the frame and lubed it generously with soap solution. I placed the windshield over the frame/gasket and put the glass into the gasket along the top, bottom and upper sides with a little stretching of the frame to get the top and bottom in. Then I used the windshield stick tool (I think I got it at VB) to work the glass into the gasket from the sides down and the lower frame out, working towards the lower corners. It worked best to push the inner lip of the seal past the frame with the stick on the outside pushing in.
There is a slot in the gasket, with a filler strip that is installed after the glass is in. The slot side of the gasket goes to the interior, and allows the inner lip to bend more, giving you the clearance needed to get it past the glass. The filler slip is pushed into the slot afterwards.
Overall, fairly easy, with not surprises or particularly troublesome issues. It takes a little patience and go slow, but as BE projects go it is not one of the more difficult.
Here are some pics of the process:
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Boink
Bronze
Fantastic how-to post! Thanks. Great reference.
Rut
Fred,
You amaze me with your ability to do everything related to a Bugeye! I've used several of your 'how tos' along my Bugeye restoration journey and I thank you for that. I'm not up to the paint challenge, but I'll try most everything else.
Thanks, Rut
TulsaFred
TulsaFred
Thanks guys. I'm a big fan of doing it yourself, as I think that's the most rewarding aspect of this hobby. These cars are from an era of analog mechanical systems and room too work on those systems. They are intuitive to work on in a way that the modern computerized high tech vehicles are not.
Believe me, if I can do it, we all can. I'd rather have a mediocre car that resulted from my own efforts than a show car someone else did.
I say go for it!
64rocksprite
Great write up and how-to pics. Agreed, everything you can find on the web says "I took it to a glass shop"..this is one of the last things on my list that needed refreshed, good to see it's not a king-kong ordeal to handle!
Thanks Fred!
SD Bugeye
The picture with the installed stick excellent saving it to simplify explanation to people on how correctly use it .
perfect!
nomad
Spose it could be done on the car???? Screw's of the side posts are commonly corroded. I have several frames passed on by a friend and I think that most of the screws on them have been stripped.
Kurt
Joe Schlosser
Has anyone tried using a piece of string around the whole gasket to pull it over the glass. I used this method in the 1980's on a Volvo 122. Put string inside channel with ends coming out. Glass on rubber. Pull string and rubber slides over the glass.
Rhodyspit75
The Bugeye is a different fit. You put the rubber into the frame first so the string method won’t work. I did two VW windshields with a cord and it was relatively easy.
S Bugeye Windshield Seal Austin Healey 1
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
H Bugeye Windshield to Body Gasket Spridgets 1
Rut Bugeye windshield to body seal Spridgets 8
P Bugeye Windshield Wipers Spridgets 7
P Bugeye Windshield Wiper Motor Spridgets 3
oud272 Bugeye Sprite - Which Windshield Spridgets 7
P Bugeye windshield Spridgets 3
J Confused about Bugeye windshield to body seal. Spridgets 15
The_architect Windshield washer container for Bugeye Spridgets 14
L Bugeye windshield glass installation Spridgets 13
I Stripped screws in Bugeye windshield frame Spridgets 10
Ohiobugeye Bugeye Windshield Wiper Installation OUCH !!!! Spridgets 3
B Bugeye Windshield Frame Coating? Spridgets 2
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
