Can't find my hub puller and puzzled about how to apply pressure against the threaded housing if I find it. Any good suggestions on how to remove the hub without a puller (I have the 3 arm type but again nothing to push against?)
I did this recently and the "drums on backward" thing worked like a charm. I laid a large wrench handle between as a spacer, cranked it off, you'll hear a pronounced "pop" or two. Then grab and yank.
I took a square piece of 1/2" plate steel and drilled it for the Spridget 4"x4" wheel bolt pattern then drilled a center hole in it to bolt my slide puller to, works great for pulling hubs.
