bugeye master cylinder adjustment help
ichthos
There are two bolts that act as stops at the end of the two push rods from the master cylinder. Where should these be adjusted to? Any help is greatly appreciated.
Kevin
Your shop manual gives all that info.
If you do not have a shop manual get one.
In the meantime ask again and I will try to type all the set up info.
I looked in my manual and didn't see anything. I'll look again a little harder. Would I find it under clutch, brakes, or both?
Kevin
Heh, it is called Pedal Free Movement and is adjsted with a pair of 7/16 open end wrenches.
The spec for both clutch and brake is 5/32 of an inch.
Data is found in the General Data section of the workshop manual under clutch and under brake as well.
Enjoy.
This is one of the worst-documented adjustments in the whole manual. Yes, there is a spec for pedal free movement, but it doesn't tell you how to measure it. Also, there are two adjustments--the pedal stop and the pushrod length. They have different effects.
Because of this dilemma, I've had to worry it out myself, and I'm still not sure I've got it really right--but it does work OK. The pedal stop essentially sets the amount of travel. This should be 0.4-0.5 inches at the master cylinder. Then, the pushrod is adjusted so it is just short of the point (like, 1/16" or so) where the pressure starts to build up as you push it into the cylinder. This point is a little difficult to assess--there is a fraction of an inch where the MC's piston moves but it doesn't move any fluid to the clutch. (It goes back into the reservoir.) The idea is to get past this point. Now, I have an aftermarket MC, so, to complicate the matter, yours may be a little different.
If you get this wrong, you might not have enough motion at the slave to release the clutch completely. You don't want so much motion, however, that something hits its limit of its travel.
If you figure out a better way to do this, please let me know.
Good luck!
You about got it Steve. It is a PITA for sure. However, you only have to do it when you remove the Master Clynder. I think I have only had to do it three times in my life.
Everytime was a bit of a pain cause i am a slow learner.
Pedel free movement is measured from the head of the nut to the push rod clevis or what ever, just a bit of movement to the pedals when hanging free.
