bugeye locking trunk panel
ichthos
At a British car show in Portland, I saw one bugeye with a locking trunk panel. There is currently one for sale on Ebay, but after one day, it is already up to $250 and will soon be way out of my budget. They look easy to make. Does anyone happen to know of a source for a pattern for these? Has anyone ever made one of these themselves?
Kevin
Hot Wings
I've not done so but had planned to make something similar for my project. The idea was to reduce the cockpit volume to make heating better for winter use, not for lockable storage. Now that I see someone has already worked out the basic configuration I'll have something to copy that serves a dual purpose. Looks like a pretty basic project that shouldn't take a lot of effort. I think I'd prefer a composite sandwich construction rather than the Birch plywood. It would be lighter and longer lasting.
Jim_Gruber
So us there a picture of same? Curious.
Whitephrog
paulsherman
Ray, do you have, or can you make me/us a paper pattern? A few years ago, you sent me paper patterns for all of the other panels, which I have rough cut into 1/8" Masonite panels, ready for final fitting and then vinyl covering. This is still part of my THIS WINTER projects, but time is fleeting and I am procrastinating.
Jim_Gruber
Ray is that a commercially produced item that is still available or a custom one off? Thinking access to remove tire as needed might be tough. I'd want it set up with some sort of internal clips, latches to make it easily removable but still somewhat secure and hidden but still be able to easily wrangle the spare out if needed.
Gerard
I had a friend with one of these. Pretty nicely made, but it's something that was available decades ago. It was well over 10 years since I have seen it, and he had bought NOS even before that. What was available NOS was sold long ago, so the only source is something like this embay auction where someone is parting with one.
AN5Sprite
That piece looks symmetrical and flat so it would be very easy to make your own pattern.
1. Scribe one side of the wheel arch etc on some card stock with a pencil compass to make a 1/2 pattern
2. make it fit nice
3. check fit on other side
4. measure distance side to side
5. on some 1/8" MDF or tempered hardboard, trace 1/2 pattern, measure over and trace pattern on other side...
Use this piece as a full size pattern if you want to make it out of something stronger.
Cut, fit, make door, hinge, lock, trim etc.
Boom done!
Whitephrog
Not mine. This is a photo of the one available on eBay.
mightymidget
masonite asbords moister and will grow (warp,bow) during high moisture air content. a 1/4 lauon would work well, especial in a hardwood as mention in earlier post
sqbsprite
BMC had a good fix for this problem. They called it the Mk. II. Sorry I couldn't resist. Seriously, it does look easy to make. I think the opening would be large enough to get to the spare. Use some stiff cardboard to make a pattern and transfer it to lauan plywood. I would be tempted to use a piano hinge across the bottom. and an X brace on the back of the door.
pbraun
This thread is a bit old, but anyway............ I am investigating building an opening trunk lid. Has anyone done this recently? I am wondering how a MK II lid would adapt to a bugeye?
nomad
My bug eye has stud's for a short tonneau. I always figured on the right tonneau or a specially made up piece would isolate the rear fairly well. Plenty of noise comes from back there as well.
Kurt.
lewmac
Hi Gerard,
Just realized this is an old thread ! But I had saved this and a few other pics, must have been from that eBay advert ......
Cheers
Lew
pbraun
That's very nice for a front closure. Frankly, I don't care about security, I just want to get stuff in and out of the boot area with greater ease. So, I got a used Mk II trunk lid. $75. With hinges and handle. Cut off about 3" from the bottom.
It actually fits up to the bugeye pretty good, in terms of conformity to the body lines. Will have to do some reinforcing I think, and make a drip channel, but I think this will work. Pictures coming soon.
pbraun
OK, so here is the template, and the bit cut off the Mk II lid.
attachment.php
attachment.php
pbraun
The curvature conformity is astounding.
attachment.php
attachment.php
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
B Bugeye Electrical Diagram with additions Spridgets 6
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
R Bugeye reverse gear Spridgets 6
