Bugeye ignition and light switch
My headlights are flickering on and off, and I've traced the problem to a red wire that enters the back of the light/ignition switch. The problem is the whole area I'd wrapped in black electricians tape, so I can't really see anything. I've never removed this unit before, but there appears to be a circular clip around the read of the unit. If I loosen this, how does the whole thing come out-do I separate the rear unit from the black circular switch, and if so, how? It's all so old and fragile that I don't want to make it any worse than it is!
thanks! :smile:
larry
drooartz
You pop that clip off the back, and the whole switch comes out the front.
longbridgehealey
OK, thanks! It's such a mess back there that I didn't want to start in not knowing the plan!
60Bugeyefan
Once you pop the clip off the back you can pull the whole switch and the wiring through the hole and disconnect the 4 wires on the back of the switch. This is easier than trying to do on your back lying underneath the dash. The black ring is held in place by a spring loaded pin that can be pushed in with a small screwdriver. The cylinder lock can also be removed easily. You can buy a repro switch from Moss or look on ebay for NOS which run between $50-$90. If you by a NOS switch make sure to put a meter on it before going through the hassle of installing the part. When you install the new switch you can use the clip that comes with the part (putting the nut on the clip and tighening under the dash is a pain) you can alternatively use a hose clamp which is easier to install and will hold the switch in place more firmly.
longbridgehealey
Sounds good. I'm going to remove it tomorrow, and decide if I need any new parts, or just rewire. All of the black tape worries me:smile:
drooartz
What, and remove all the fun of working on a Bugeye? :grin:
Not working on the dash in this pic, just flip 180* for underdash work...
Jim_Gruber
And disconnect the battery before you start working under there.
longbridgehealey
:smile:
Sarastro
If I may suggest, don't use electrical tape in automotive wiring. It quickly becomes a mess, as I think you are discovering, then dries up and comes off. Use heat-shrink tubing to cover wire connections, and solder them or use crimp connections to join wires to each other or to eyelets or spade lugs or things like that. You'll end up with a much neater and safer job, which will last.
nomad
If its the switch, they are not too hard to take apart and you may be able to repair it. I have a couple of "parts" switches somewhere that I was always going to combine into one good one.
Kurt.
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Navigation Questions 4
Rut Bugeye light-ignition switch Spridgets 6
I Bugeye ignition light still on- help please Spridgets 35
R Bugeye ignition switch Spridgets 2
R Wanted Bugeye ignition switch Spridgets Classified 2
longbridgehealey Bugeye ignition switch Spridgets 4
A bugeye ignition switch Spridgets 2
A Bugeye ignition switch Austin Healey 3
W Bugeye ignition key repalcement Spridgets 2
longbridgehealey New Bugeye ignition switch question Spridgets 10
H Ignition Switch Bypass Help - '61 Bugeye Austin Healey 6
TulsaFred Bugeye ignition combination switch Spridgets 11
I Bugeye 948 ignition timing help please Spridgets 8
I Bugeye ignition coil wire help Spridgets 7
ncbugeye Access to Bugeye ignition switch. Spridgets 3
L Bugeye Ignition problem Spridgets 12
B Bugeye Ignition Switch Spridgets 2
T Bugeye Ignition Wiring Spridgets 10
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
