Rut
I've toyed with the idea of upgrading to an alternator, but with the limited use of the car and wanting a period look I decided to stay with my generator. I stopped by an old generator/starter shop and they checked it out and everything is good but the fiber insulator that goes between the two terminals. The terminal with the square base accepts the fiber insulator without the insulator being sandwiched between the terminal and body of the generator, correct? I also serviced the bushing oiler and used 20 wt to soak the cotton wick which is what I used in the tach drive. Does anyone have a detailed picture of this end of the generator? I've googled it without success and want to make sure I'm doing this correctly.
Thanks, Rut
Thanks, Rut
Hi Guest!
