Jimflorida
Is the metal gearshift cover for the Bugeye available from anywhere? I did not see it from Moss or AH Spares. Jim
Jimflorida said:Is the metal gearshift cover for the Bugeye available from anywhere? I did not see it from Moss or AH Spares. Jim
twas_brillig said:Gerard - I'm trying to finish up a Datsun 5 speed conversion (currently struggling to get the after-market clutch slave cylinder/rebuilt master/system to bleed): with your ring, do I need to do the cut & weld thing with the Datsun shift lever? Our BE is pretty much stock, but using your ring & a gaiter with a shortened (ie not cut/spliced/welded) Datsun shift lever would make life easier. And NO! I won't be tossing or selling the original BE metal enclosure!
Thanks,
Doug
Pythias said:As an aside, Gerard is one the "good guys", ala PPP Hap, Jeff, Paul A. Quality, reliability, S.O.P.
