Bugeye front drum brake picture
paulsherman
Does anyone have a photo (or diagram) of the front drum brakes for a 1960 Bugeye. I have been putting this car together form boxes of parts I got years ago. I need a picture showing the layout of the backing plate, from the inboard side (wheel cylinders, cross pipe between cylinders, location of the bleed nipple and where the brake line attaches).
All the parts are new and installed, except that when I tried to hook up the brake hose it seemed short. Maybe I have the cross pipe in the wrong position. I have it connected to the upper ports in the wheel cylinders. No pictures of this in the factory manual or in parts catalogs.
Anything will help.
Thank you
jlaird
Look at the Moss parts book. It is almost as good as a picture and maybe better.
Whitephrog
Does this help?
jlaird
I should think, and I have been wrong, but a Bugeye is so simple that it could be built with the Moss parts list plus engine specs.
P
paulsherman
David, never too late. I had the crossover pipe in the top fittings of the wheel cylinders. Corrected that, then tackled the rear brakes, which I was able to fix with the help of others.
Thank you
I Bugeye front brake drum temp? Spridgets 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
W Best source for Bugeye front shocks Spridgets 3
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
Keith_M bugeye front tilt hood fastener -- choices Spridgets 9
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
T To use front bumper on Bugeye or not? Spridgets 29
Rut Bugeye front tilt latches Spridgets 24
Rut Bugeye front frame rails Spridgets 7
drooartz Front tow eye for a Bugeye Spridgets 11
M Looking for this rare front for a Bugeye Sprite Spridgets 9
P Bugeye Front Wheel Bearings? Spridgets 1
T stock bugeye front springs Spridgets 4
Rut Bugeye front suspension Spridgets 0
B Bugeye front end Spridgets 0
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
bugedd Bugeye front lowering springs Spridgets 0
TulsaFred Bugeye front suspension Spridgets 41
regularman Has anyone here put a bugeye front end on a square Spridgets 2
T My buddy Rocco in my 64 Sprite [with bugeye front] Spridgets 2
6 Front Steel Insert For Bugeye Top. Anyone Have One Spridgets 7
I Bugeye wiring help for front turn indicator Spridgets 13
R Bugeye front shocks Spridgets 3
M Bugeye with late model front end ? Spridgets 16
toysrrus Bugeye: "FRONT TILT OR REAR TILT"? Spridgets 16
I Front suspension rebuild help for bugeye Spridgets 6
I Price for good used front bugeye spindle axle? Spridgets 2
I 60 Bugeye front suspension torque settings? Spridgets 4
Jim_Gruber Front Hinged Bugeye Bonnet/Getting to curve back i Spridgets 6
mrsprite Bugeye front bumper wanted Spridgets 19
I Bugeye front bumper Spridgets 9
T bugeye front tilt bonnet Austin Healey 4
Steve P. Bugeye front bonnet tilt: anyone built their own? Spridgets 3
N Front line suspension for a Bugeye Austin Healey 4
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
