Bugeye bonnet hinge bolt head busted off - ideas?
ichthos
One of my hinge bolts for the bonnet is rusted pretty good. I torched it at both ends, put on my ratchet, started to feel like it was loosening up, and the head snapped off. Anyone have ideas on how to proceed from here?
Do you mean the pivot bolt?
BlueMax
Scuff the area where broken head was, then mig weld a nut to shank of bolt, making sure you have a good weld by filling the entire hole of nut with fillet, high heat!! Fillet must lay to shank of bolt first or nut will sheer off. After cooled apply heat to the threaded side of hinge apply PB Blaster generously, let it soaked in overnight. Next day heat the area up again at the threaded side of hinge then quench with ice water spray while you unscrew from welded nut.
I
ichthos
Yes, it is the pivit bolt, Trevor. The problem is that the bolt head busted about 1/2" inside the hinge. I don't think I could get a nut welded on without welding it to the body. There is about 3/8" of thread sticking out at the opposite end. I thought about welding a nut there, but since the rest of the bolt has no threads, I would only be able to move it so far unless I cut through the body to remove the rest of the bolt first. I have busted off three bolts on this car just using a ratchet-any tips in general for not breaking screws an bolt to begin with?
Jim_Gruber
Liberal doses of PB Blaster or something stronger like Acetone/ATF 50/50 Mix. I've got the same issue with a broken bumper suport bolt broken off at the frame ends. Can't get in there to weld to pull it out as bolt is broken off just below surface. I do not think that one is threaded and I may be able to get out with some drilling from the opposite side.
The idea of front hinging may be getting a little more thought.
Start drilling the threaded end. Since you are going from that end you may get luck and the drill might bite and turn the bolt.
I
ichthos
Thanks for the hinges and bonnet supports-and at such a great price, Paul. It was nice to meet you and see your projects. Back on the homefront-Finally got the bolt out after a few hours. Welding nuts back in the bonnet and it should be back together tomorrow. Thanks again everyone for your suggestions and help.
I Anyone have a bugeye bonnet hinge or bonnet stay they could sell me? Spridgets 5
M Tilt Bonnet Hinge Kit 4 BugEye Spridgets 8
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
Rhodyspit75 Bugeye bonnet prop rod Spridgets 2
Rhodyspit75 Bugeye bonnet brace. Spridgets 5
M Bugeye Tilting Bonnet Hardware Spridgets 2
Gerard Bugeye bonnet and entire rear clip Spridgets 4
A Best fibreglass/GRP Bugeye bonnet Spridgets 21
Rut Bugeye bonnet insulation Spridgets 4
Rut Bugeye bonnet handle escutcheon Spridgets 9
Rut Bugeye bonnet mirror Spridgets 11
Rut Bugeye bonnet fit Spridgets 19
Rut Bugeye bonnet gas struts Spridgets 6
Editor_Reid Securing Bugeye Fiberglass Bonnet Spridgets 15
TulsaFred Bugeye bonnet prop rod Spridgets 7
6 crossflow radiator with bugeye bonnet? Spridgets 5
Rut Bugeye bonnet Spridgets 0
DanLewis New fiberglass Bugeye bonnet $395 [NFI] Spridgets 0
Rut Bugeye bonnet Spridgets 1
Rut Bugeye bonnet Spridgets 5
bugedd Bugeye bonnet differences Spridgets 9
I Help removing bugeye bonnet please Spridgets 5
P Bugeye Bonnet Latches Spridgets 7
Hairyone bugeye bonnet radiator cowl Spridgets 3
I bugeye bonnet welding help please Spridgets 11
Rut Bugeye bonnet latch Spridgets 13
RickB Bugeye Bonnet $100 on Santa Barbara craigslist-nfi Spridgets 1
The_architect Bugeye bonnet badges Spridgets 7
M Bugeye bonnet sheetmetal question Spridgets 12
I Tips or installing Bugeye bonnet needed Spridgets 14
Trevor Jessie Bugeye rear ends 100-6 [needs a bonnet] Spridgets 11
I Bugeye bonnet gaskets - do I really need these? Spridgets 10
I bugeye bonnet wiring harness fasterner help Spridgets 16
R bugeye bonnet Spridgets 7
P Bugeye bonnet on Craig's list Seattle Spridgets 6
RickB Bugeye Sprite Bonnet found on Ebay only $2900!!! Spridgets 11
Morris Winner's circle Bugeye Bonnet Spridgets 4
M Bugeye bonnet mounted on later sprite or midget? Spridgets 21
Jim_Gruber Front Hinged Bugeye Bonnet/Getting to curve back i Spridgets 6
Jim_Gruber Bonnet Seal / Bugeye Bonnet on Mark IV Sprite Spridgets 5
Branson Free bugeye bonnet <-- well almost Spridgets 1
drooartz How many guys to pull a Bugeye bonnet Spridgets 19
Jim_Gruber Getting the curve back in a Bugeye Bonnet Spridgets 3
Jim_Gruber Bugeye Bonnet Installation Up-date Spridgets 3
Jim_Gruber Trimming Inner Fender for Bugeye Bonnet Spridgets 13
racingenglishcars Jyllandringen grand prix Bugeye bonnet Racing 6
Morris Bugeye Bonnet SWA Butt Spridgets 0
John Moore Bugeye Bonnet Question Spridgets 6
