Since 3Mās website is pretty useless, I called their tech support. They said Finesse-It II 39003 is a fine finishing polish. It will not remove sanding scratch. You will need to use a compound after sanding and before the 39003. (They also said 39003 is a discontinued product.)... The finesse ll compound is a polish and I have that Black Ebony glazing I might try when I get the orange peel down enough and after I use the finesse ll. ā¦.
3000 paper does not provide high gloss. Nor does any other paper used in the auto finish industry.ā¦. I guess there is new 3000 sound paper that kinda looks like a leather pad. I picked one a pad of it, but have just been using it by hand when I get buildup of paint from wet sanding. The 3000 stuff is supposed to provide a very high gloss, ā¦.
Buffing does not remove orange peel. Buffing makes the finish glossy. If you buff orange peel you get glossy orange peel.⦠when you were doing the "color sanding" and got to those little tiny low spots maybe 1/16 in diameter between the orange peel-- did you leave any of them shinny so the buffer would remove paint and come down to them. ā¦.
.... Yesterday I was behind this new black Mercedes SUV and noticed the orange peel from 10 feet away on a beautiful vehicle. So I can see now this paint world is the lunatic fringe ...
Every Mercedes I've worked on that's newer than about 2010 has a level or orange peel that I would find unacceptable from any collision shop fender repair. I'm not sure if it's the way the clear is applied or a byproduct of the paint they're using.Yesterday I was behind this new black Mercedes SUV and noticed the orange peel from 10 feet away on a beautiful vehicle.
With the DA you only need to control overall pressure (light) and placement. When hand sanding you need to control those plus direction, angle, pressure at each point in the arc, etc. And again, there is no way a human being can replicate exact motions thousands of time in a row.I don't believe you have more control with a machine than your hand. After all, your hand is controlling the machine. ā¦.
If you work clean you won't get chunks big enough to feel, especially if youāre using a block. A human hand will never be able to feel a few 800 grit particles while sanding with 1200 paper. But you will be able to see the resulting deep scratches. That means going back and re-sanding or spending way too much time buffing.ā¦. You can tell in an instant if a bit of dirt is under your paper using your hand. Not so with a machine.......
There are linear sanders. But the machine of choice for finish work is the dual action sander, which makes an orbital motion, not a circular motion. And since the machine is controlling the orbit, not human muscle, the scratch produced is extremely controlled and consistent....and as for direction, the buffer works in a circular motion, doesn't it? Wouldn't there be linear buffers if straight was better? ā¦.
The best shine is produced by the reduction and elimination of microscopic scratches. When all the scratches are aligned a process that removes one will remove them all. Scratches that are randomly distributed will also be randomly removed and randomly left behind, making for more work buffing.ā¦. But in general a shine is a combination of many tiny microscopic scratches oriented in many different directions. On large flatish panels circular sanding and buffing produces the best shine from any viewing angle. If all the scratches align, then the finish will appear different from different angles.
The machine is dual action sander. Its motion is orbital, not circular. But if you want to think of it as a compound combination of modified arcs, thatās reasonable.Thatās a circular sander...am I missing something?? I thought the discussion was linear strokes vs circular.....
Could have been a lot of things. Thirty years after the fact itās impossible to say what went wrong. but I believe that if you had gotten good advice and instruction you would have had a much different experience....Oh, just sitting here thinking. I forgot that I used a pneumatic sander just like in the utube vid on a Cadi back in ā86. I watched a film and a shop was using those to crank out the pre-paint sanding, so I thought that was the ābombā and bought one. Granted, I may have used it all wrong, but the finish came out horrible. The sander cut lows and highs in a finish that was straight before I started. It was the second worst finish I ever sprayed.
I chucked the sander. ....
Like I said earlier, Iāll have to agree to disagree. I believe the opposite. I believe you can do it better and faster..... Since the dawn of time all the best finishes have been āhand rubbedā. You can do it faster, but not any better. ...
Any tool can be misused. And itās certainly common enough for these particular tools to be horribly misused by body shops that donāt care about quality and are only interested in minimizing costs. But that says nothing about the tool and everything about the user. And these tools arenāt used exclusively by bottom feeders..... The last bodywork I had done by a shop was a Jag about 2 years ago. I sent it back 4 times until they got it right! I wasted more time driving back and forth than if I sprayed the bumper myself in the end. Shops are interested in cranking a profit. They are not always the best source for ābestā way...they are for āfastestā.
Maybe Iām confusing things a little with the way I use the term ācircular.ā Being sort of OCD I think of textbook mathematical circles, very round things with a single, constant radius, or at least something very close to that.ā¦Last time I checked an "orbit" is circular. I still do not understand how a circular arc by a power tool is different than a circular arc by hand and block. Are you saying the size of the circles makes a difference? I look at it from the opposite perspective, in that it is not impossible for one's hand to duplicate the power tool, but rather the power tool can never entirely duplicate one's hand.
I obviously think otherwise. But since thereās no way to put it to the test though our keyboards weāll just have to continue to disagree.I think we both have different definitions of "difficult to buff out". I assure you I can beat any machine sanded surface by hand. You will beat me in the time it takes, ...
Iād say this is the core of our disagreement. Unless we meet in a garage somewhere and play with it all on paint with our own hands (and machines ;-) ) we will continue to disagree.... A professional hand rubbed finish is as close to perfection as you can get...
.... Watch the Smithsonian show on the Bentley and Rolls finishes...they are still hand rubbing them. I think that pretty much says it all...when time and money are not a factor (like our hobby painting) Bentley still hand sands every carā¦.
