I have just installed a Pertronix FlameThrower disdributor in my 67 BJ8. I am not sure how to connect the wiring. I have a white/black wire that goes to the old distibutor, two white/black wires going into one connector going to the negative side of the coil and a solid white wire going to the positive side of the coil. These wires originate from the wiring harness. The petronix distibutor has a red wire to the positve side of the coil and a black wire to the negative side of the coil there is not a receptical on the Petronix for one of the white/black wires. Do I reconnect the existing wires back to the coil and just connect the wires from the Petronix to the coil also? I am very concerned that experimenting with the wiring will burn out the electronics. Does anyone know how to connect these wires?
