Deleted member 21878
good point. i will give it a try. seems they would know. also want to send them a note and ask.
there is a lip inside the boss that is flat and the screws come in just in front of this lip. the backing plate is up tight against that lip.
adjustable steering column so i can pull the boss out or push it in. the distance remains the same which made me thing it was not an issue with the stator tubes. but again, i may as well give it a shot. i could certainly be missing something.
thanks for the suggestions.
