Healey Nut
So one end of the Panhard rod connects to the driver's side rear axle. Where does the other end go?
Pics anyone, pls?
Pics anyone, pls?
Ah ha , mystery solved I have a Jule superstructure so no bracket on the frame rail so no panhard rod for me .There should be a bracket on the right side frame rail with a hole. It is on top and at the outside edge of the rail.
The bracket should probably be welded, rather than bolted. In 2019, when repairing my rear axle, I found my Panhard rod was bent (I already replaced it) from excessive side loads.The panhard rod bracket for the chassis rail is available. So I could if I wanted buy the bracket and weld a plate between the base edges then drill tap the chassis rail and bolt it to the chassis rail to create the end connection for the panhard rod .
but it does seem though as if itās not required with the Jule frame set up .
A panhard rod has nothing to do with how solid a chassis is. It is there to prevent lateral movement of the rear axle.I have Martyās frame in my BT7. No panhard rod or radius arms required.
Been in my car since 2008. Rock solid.
Lin
I will take some measurements off my superstructure and report back .Does anyone know the exact amount of leaf spring toe-in that Marty put in his chassis'? Are the mounting brackets still parallel to the chassis or are they angled to align with the now toed-in leaf springs?
I have done some research in the past on this subject. Some American cars and trucks have had rear leaf spring toe-in. I one case I read about a vehicle that had 3" of toe-in although that is certainly the extreme. Toe-in will resist spring twist and lateral load but It will also increase roll stiffness. Increased rear end roll stiffness will also induce oversteer, also known as looseness....... which can result in spinning out. Installing an anti-roll bar (sway bar) on the rear will also increase roll stiffness and that is why I strongly recommend against it in a big Healey. Other cars that have different handling charactoristics may benefit from a rear bar.
