broken sway bar link
Hoghead
My BJ8 sway bar end links were bent at the threaded ends so I fitted new ones with urethane bushings from Moss along with urethane centre bushings.
Now the R link has broken on the bottom end at the thread where the bushing is located
Difficult to see how I could be installing it incorectly but it would not be the first time.
Am I doing something wrong, or is it the urethane bushings
If I recall correctly, the anti-roll bar links should be tightened up with the car on the ground and the front suspension in its normal laden position. Also, snug up each nut on the links just so the bushings start to compress. That said, I've only used standard rubber bushings so I can't say it's NOT the urethane bushings causing the problem.
Bill - loaded it as you suggest
My end links are not at right angles to the bar and at a rather acute angle, putting a lot of stress on the end link. It is no wonder the stock one bent and does not look right
I was wondering sbout that too, and if there is a way to mount something incorrectly you can bet I tried it first
There are good drawings of the front suspension and steering in the factory shop manual. Is the anti-roll bar original? An incorrect part may be to blame as much as incorrect mounting would be. When I first restored my 100 I found that one front spring was 3" longer than the other. I never figured out what car the wrong one came from.
I hope my enclosed photo helps and I hope I did mine correctly. Haven't had any problems, thus far.
pkmh's picture shows how it should look. If yours doesn't look like it start replacing parts (start with the cheap ones first!) until it does. I don't see how wrong links could be the culprit. Wrong bar?
One picture from the internet;
And one from my own car, with blue polybushes. Note the extra strip to hold the Spax shockabsorbers (behind the original spring)
Hans
Hoghead said:
mine is not straight up and down like that, and my ends are splayed outboard
I suspect something is or was wrong up front.
As evidenced by your shocks.
Contact me, please.
Peter
Probably not on backwards. My guess, you've just got them on the wrong side - swap the right to left and left to right and everything will line up.
